Secure ssr302 2 channel boiler switch
Please ignore my ignorance if I have posted in the wrong topic but I’m just a newbie here.
I have tried to set up a secure ssr302 2 channel boiler switch to use with SmartThings. When it is added it is seen by ST but I can not seem to set up the 2 channels to switch. Has anyone any ideas where I may be going wrong. Many thanks in advance.
I’m not seeing it on the list of supported devices:
Until there’s a device type written for it (whether by ST or someone in the community), it likely will not function correctly.
I’ve released a device handler…
It works alongside a smartapp that populates the temperature (and humidity if available) from a separate temperature sensor. Should be fairly straight forward but let me know if you need any help.
