Here’s a modififcation of the standard Smartthings z-wave device handler for use with the Secure SSR303 (also known as Horstmann ASR-ZW) boiler switch.
This is a dry contact relay. It’s a z-wave switch but identifies as a thermostat. I’ve modified the standard template to take issue thermostat command instead of the standard switch commands in order to turn this switch on and off. It has no other functionality.
Fingerprint also updated so that it is identified once the device handler has been installed via the IDE and you connect it to ST as a thing.
Full details can be found here:
http://www.vesternet.com/z-wave-horstmann-z-wave-controlled-boiler-receiver-hrt
Manual here: http://www.vesternet.com/downloads/dl/file/id/519/product/502/z_wave_secure_boiler_receiver_hrt_manual.pdf
Note that I think this device is available in the EU only.
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Device Handler for a Secure SSR303 (aka Horstmann ASR-ZW) Boiler switch
* Standard ST Z-Wave switch modified to turn this device on and off. This device identified as a Thermostat (as opposed to a switch).
* http://www.vesternet.com/z-wave-horstmann-z-wave-controlled-boiler-receiver-hrt
* Note that the Horstmann HRT4-ZW and the ASR-ZW are being sold today as a 'Secure SRT321' (Thermostat) and 'Secure SSR303' (relay switch).
* This DH allows the relay switch to be controlled directly by ST. To clarify, this DH is for the ASR-ZW or the SSR303.
metadata {
definition (name: "Horstmann HRT4-ZW", namespace: "smartthings", author: "SmartThings") {
capability "Actuator"
capability "Indicator"
capability "Switch"
capability "Polling"
capability "Refresh"
capability "Sensor"
// fingerprint mfr:"0063", prod:"4952", deviceJoinName: "Z-Wave Wall Switch"
// fingerprint mfr:"0063", prod:"5257", deviceJoinName: "Z-Wave Wall Switch"
// fingerprint mfr:"0063", prod:"5052", deviceJoinName: "Z-Wave Plug-In Switch"
// fingerprint mfr:"0113", prod:"5257", deviceJoinName: "Z-Wave Wall Switch"
fingerprint mfr:"0059", prod:"0003", deviceJoinName: "Secure SSR303 Boiler Switch"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
preferences {
input "ledIndicator", "enum", title: "LED Indicator", description: "Turn LED indicator... ", required: false, options:["on": "When On", "off": "When Off", "never": "Never"], defaultValue: "off"
// tile definitions
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("indicator", "device.indicatorStatus", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "when off", action:"indicator.indicatorWhenOn", icon:"st.indicators.lit-when-off"
state "when on", action:"indicator.indicatorNever", icon:"st.indicators.lit-when-on"
state "never", action:"indicator.indicatorWhenOff", icon:"st.indicators.never-lit"
standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch","refresh"])
def updated(){
switch (ledIndicator) {
case "on":
indicatorWhenOn()
break
case "off":
indicatorWhenOff()
break
case "never":
indicatorNever()
break
default:
indicatorWhenOn()
break
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x70: 1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result?.name == 'hail' && hubFirmwareLessThan("000.011.00602")) {
result = [result, response(zwave.basicV1.basicGet())]
log.debug "Was hailed: requesting state update"
} else {
log.debug "Parse returned ${result?.descriptionText}"
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
def value = "when off"
if (cmd.configurationValue[0] == 1) {value = "when on"}
if (cmd.configurationValue[0] == 2) {value = "never"}
[name: "indicatorStatus", value: value, display: false]
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
[name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
log.debug "manufacturerId: ${cmd.manufacturerId}"
log.debug "manufacturerName: ${cmd.manufacturerName}"
log.debug "productId: ${cmd.productId}"
log.debug "productTypeId: ${cmd.productTypeId}"
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
updateDataValue("MSR", msr)
updateDataValue("manufacturer", cmd.manufacturerName)
createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
// Handles all Z-Wave commands we aren't interested in
def on() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 1).format(),
zwave.thermostatModeV2.thermostatModeGet().format()
], standardDelay)
def off() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 0).format(),
], standardDelay)
def heat() {
delayBetween([
], standardDelay)
old code:
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
], standardDelay)
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
def refresh() {
delayBetween([
void indicatorWhenOn() {
sendEvent(name: "indicatorStatus", value: "when on", display: false)
sendHubCommand(new physicalgraph.device.HubAction(zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()))
void indicatorWhenOff() {
sendEvent(name: "indicatorStatus", value: "when off", display: false)
sendHubCommand(new physicalgraph.device.HubAction(zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 3, size: 1).format()))
void indicatorNever() {
sendEvent(name: "indicatorStatus", value: "never", display: false)
sendHubCommand(new physicalgraph.device.HubAction(zwave.configurationV1.configurationSet(configurationValue: [2], parameterNumber: 3, size: 1).format()))
def invertSwitch(invert=true) {
if (invert) {
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
else {
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 4, size: 1).format()
