SDC24 Innovation Challenge
Who’s planning to submit an idea for the SmartThings Innovation Challenge?
  • Propose a new feature or ways to enrich an existing SmartThings feature → Share Your Idea Here
  • Develop a new driver that enhances user’s abilities and the overall SmartThings experience → Share Your Idea Here
Why should you participate in the SmartThings Innovation Challenge?
  • Visibility: Gain visibility for your innovative ideas within Samsung, SmartThings, and our partner ecosystem
  • Community: Connect with fellow innovators
  • Support: Potentially secure resources to bring your ideas to life
  • The best part? The winners take home a Samsung 55” Frame TV!
For more challenge details, check out this post on The SmartThings Blog
Well, I think this forum is a laundry list of things that desperately need fixing ahead of any added innovations, which seem to usually break the things that are working lately.
For me, fixing the battery drain issue would be a number 1 priority. We are going on a few years now and it hasn’t recieved much attention, if any. I don’t think that it plagues everyone, so that may be why it hasn’t been fixed. For me, on my battery powered devices, I previously got 1.75 to 3 years from a battery… the past few years I am lucky to get 10 to 25 days from a battery. Chasing offline device’s to replace batteries has become a daily activity for me as I arrive home each afternoon, and has me questioning my life choices back when SmartThings was actually a viable smart home solution.
Sure, I could move on to something more reliable, but I am heavily invested in SmartThings (for many years) and have my entire family (kids, teens, wife, elderly parents in their late 80s) trained at this point. Everyone knows the most important part of any smart home is keeping the wife happy! So, I am not sure which is more painful, switching to a viable smart home solution at this point or continuing to wait for the SmartThings team to get their head out of the sand.
That is probably enough for my rant. I won’t be submitting this or any other ideas, just to have them ignored.
I’ve only had one device that had a battery drain issue like you mention. It was one of the original ST’s motion sensors that came with my v2 hub. It just started burning through batteries. I finally just replaced it with another sensor, a Ring motion sensor. Haven’t touched the batteries since. In fact, I only have a few high use contact sensors that I replace with any real frequency. I have a ton of battery driven devices, tilt wands for my blinds - those I replace about every 3-4 months, but I also use rechargeable AA’s in those so the life will be a bit less. I swapped out my Nest x Yale door locks and put in Yale Assure 2’s with ZWave, about every 3-4 months with those as well, the Nest version was every month. I do appreciate that there is now a battery level warning on the favorites page, instead of getting a last minute warning before the device just dies. Anyway, not to negate your post, just not having the same issue in my environment and I’m currently sitting at 275 devices.
You’re very lucky, or should consider yourself very lucky.
I have about 130 devices, and every battery powered device experiences the dreaded battery drain issue.
I have deleted and re-added devices. Tried more expensive batteries, cheap batteries, rechargeable batteries, wiring up AA batteries, all with little difference.
My rechargeable 123 batteries actually last a few day longer than the SureFire, Duracell, or Energizer 123 batteries in all of my water leak sensors… but a few days longer is maybe 15 days total… where I previously would get 2 years out of a SureFire 123 battery in the water leak sensors.
Interestingly, and I have reported this previously, the farther a battery powered device is from the hub or a repeater, the longer the batteries last, but none last longer than about 30 days.
I am glad you aren’t experiencing what I am experiencing, I wouldn’t wish it on my worst enemy. Lol!
This is off-topic.
What devices? I have quite a lot of battery powered devices and the batteries last up to two years.
Not sure how inovating a solution to the battery drain issues might be off topic here, but feel free to move the conversation to any of the following threads as I am very interested in how you and others might have overcome the issues:
Wow, that just sounds awful. Is there anything environmental that might be causing signal loss that would force the devices to do a lot of repeats tx or searching? I essentially live in a big Faraday cage. My walls are over 1’ thick and there is a lot of wire mesh involved. I have to use a lot of repeaters (both ZWave and Zigbee) to get my entire house covered. Just spitballing here, have you always been on the same hub? I started out with a v2 and am now running on a v3 with a secondary v3. I also repurposed my old v2 to run STHM and SLGA. Anyway, I wish you luck trying to get that under control, it must be frustrating.
Nothing environmental has changed on my end since early 2017 (same hardwired network connection to the v2 hub, same wifi access points, same house, same internet provider, same wireless device congestion in the neighborhood, same battery powered device locations, etc.), I believe a hub update introduced the battery drain issues a year or two ago.
Thanks for the luck, I can surely use it! :wink:
To me, batteries are an added failure point (as they always fail when you need them the most), not to mention environmentally bad and costly/kWh. While not always practical, for all applications, I’ve selected very few of my ST devices to be battery powered and as such I’ve minimized these issues. It takes some looking for line or USB powered ST devices, but I have found them for most ST applications and am using wired sensors instead of using batteries. Thus, I can spend my battery replacement efforts with those batteries that I can’t get around and have all failed this year (Car, UPS, Roomba, smoke alarm backup-but line powered, TV remotes, etc.).
Connected device firmware OTA updates using own files would be a great ST feature.
A little late, but here are a few things I wouldn’t mind seeing in no particular order.
  1. A better lock code manger. Closer to what Rboy Apps was providing back when we used device handlers.
  2. The ability to automate, save, and restore device states. This would make automations much more powerful.
  3. Easier, nested automations. If this, then that, if that, then automate this.
  4. Cameras within smartthings to recognize more than just motion alerts. Recognize people and animals as well.
Since this happened yesterday, is there any info on the ideas or the winning one?
Looks like it will be available here when posted
They did not link it yet in the website but it’s on YouTube already, although it’s just the winner for one of the themes, no info on the other 19 ideas or the Edge drivers theme.
I’ve not watched the whole video but it’s about the need to standardize smart home mapping so all devices (like robot vacuums, map viewers, etc.) share the same map information.
AI generated summary:
The video is about the SmartThings Innovation Challenge, which was launched by Samsung to encourage innovation and new ideas for the smart home experience. The winner of the challenge is Donish Hussein, who proposed a solution to standardize smart home mapping. Donish’s idea is to create a common view for all smart home devices and platforms, so that users don’t have to set up their home multiple times over and over again. This will make the smart home experience more seamless and intuitive.
They mention using the ST 3D map to set up presence sensors or vacuum robots.
Pretty much a no-brainer in my opinion.
My congratulations to the winner of the innovation challenge!.
I was a little surprised, since his name was not on the list of 3 finalists that were made public to those registered for the Pre-SDC24 Webinar on September 12.
I was also surprised that there were only 3 finalists on the list, without specifying which topics they were finalists for. As @mocelet says, in the rules there were 2 topics and there should be 3 finalists for each topic. I asked about this and got no response.
I submitted 10 proposals, in the edge drivers section and when I received the email to tell me that I was a finalist and to prepare the presentation of the proposal, I resigned for several reasons, the main one being that I was not going to be present in San José at the SDC24 to defend the proposal in the final, as required by the rules of the innovation challenge.
With my refusal to participate, I made a suggestion to Samsung about the innovation challenge, if they planned to maintain it in successive years:
“Nowadays there are other ways to can participate. If the objective is to try to recognize the work of these community developers and encourage them to continue contributing, SmartThings (Samsung) can do it without the need for this face-to-face show and travel thousands of km and surely more developers will participate.
Seeing that the challenge rules say that there would be 3 finalists for each category and only 3 finalists ist have been named without specifying the category, I fear that the participation has not been as expected, but I could be wrong.
I hope that in future editions this will continue and improve, it’s just my opinion.”
That’s why I didn’t submit anything.
I understood we, as in community developers or active users, were not the target. Otherwise, they should have just sent you that 55" TV and no contest would be needed! :sweat_smile:
B2B
This is what this community is for.
B2B
