Schneider Wiser
Hi,
I am new to SmartThings and I have recently bought the Aeotec hub. I am now moving to a new house where they have a few Schneider wiser devices(Built in dimmers, built in relay, 2-way socket etc).
I am now trying to figure out whether these devices will be compatible with SmartThings through my Aeotec hub.
Sorry if this has already been discussed in some other thread, I have tried to find information on this without any success.
Is there any info about the possibility to use Schneider Wiser
Got the impression that it might be problems with the Aeotec Smart Home Hub, but more possibilities with for example Aeotec Zi-Stick (Zigbee).
Does Zi-Stick means losing SmartThing?
Sorry if I have missed an earlier answer or post in the wrong topic
//Tommy
Anyone?
//Tommy
First rule of Home Automation: “the model number matters.“
Some Schneider Wiser models Will work easily with SmartThings, some won’t. You just have to research model by model. They are not on the list of the official partners.
As for this:
That is unfortunately correct. If you use the Zi-stick, then you don’t use the SmartThings app unless you use an intermediary like zigbee2mqtt , which is a lot more work to set up and probably requires an intermediary device acting as a server. :man_shrugging:t2:
Ok and thx.
Then I will start with the following:
Scheider Electric Exxact– Wiser (Connected) Wireless Switch 1-gang/ 2-gang
Modell: WDE002906 / WDE002924
E-nr: 1360688 / 1360689
EAN-code: 3606481918505 / 3606481918512
Scheider Electric Exxact- Wiser (Connected) Multiwire Universal Push-button LED
Modell: WDE002348
E-nr: 1820423
EAN-code: 3606481048028
Scheider Electric Exxact- Wiser (Connected) Multiwire Universal Push-button Dimmer LED
Modell: WDE002960
E-nr: 1360782
EAN-code: 3606482232563
Tried to find some kind of compability-list, such as - Database of Zigbee devices compatible with ZHA, Tasmota, Zigbee2MQTT, deCONZ, ZiGate and ioBroker - without success.
I hope I did better…:slight_smile:
//Tommy
