I’m confused…ever since I went to the V2 hub, my schlage door/window sensor doesn’t work. I tried changing the device type in IDE, but it’s not showing schlage…any thoughts??
Just to be sure, you excluded the device, and then reincluded it to hub v2? What do you mean by doesn’t work?
I’ve got tons of these sensors, and they work perfectly. You do not need to do anything in the IDE with them since use the default Z-Wave Door/Window Sensor device type.
