Schlage Nexia Lock Remote Administration
Schlage locks are “supported” using the standard Device Type. No cutting and pasting required. However, you will not be able to add, view, delete User Codes. Only lock/unlock and see status.
If you want to get better programming options, use this:
That will let you turn Auto Lock on/off, turn Lock and Leave on/off, set Alarm Sensitivity, and query status and battery life.
If you want to set, delete, view User Codes, use this:
-Rob
