Which ST hub do you have and which app are you using? Any custom code for locks, if yes, try saving/publish for me again in IDE. Have you tried rebooting the ST hub? How close is the lock to the ST hub when trying to connect it?
It is about 20 feet away and it says it connects. I have tried to restart the hub. Using the smart things app and a 3rd gen hub.
This started just a couple days ago. Had been connected up until that point for the last 3 months with no issue. Below is what I get in the smartthings app.
I hope this is what you need? I just logged in and now it says disconnected. Lock is probably 20-30 feet from hub. First issue I’ve had in the 3 or so months I’ve had it.
RBoy
#8
No, you’ll need to go into the ide (account.smartthings.com) and then login and nagivate to:
Login to your IDE -> My Devices -> Click on your lock -> What’s the network connectivity state shown (like S0_FAILED or S0_LEGACY etc)
Is that what you need? I hope this helps, in smartthings it shows as offline. Yesterday after excluding and reinstalling it worked for a minute then stopped again.
I gave up on my Schalge Connect months ago. Good until you upgrade the hub or need to reconnect then its dead no matter what you try. As a lock, they are very good but the connectivity part sucks.
