I have a Schlage Connect BE469ZP CAM 619 Z-Wave Plus Smartlock which has been working great since October. I recently purchased a new front door, and had the lock installed on the door by the installers. Since then it has gone through 3 sets of fresh batteries. They last one day and are dead the next morning.
To try to determine what is causing the drain I have gone through the below troubleshooting steps, but the batteries still die overnight.
Day 1: Batteries dead. Install new batteries.
Day 2: Batteries dead. Install new batteries. Exclude lock from Smartthings. Reset lock to factory default settings. Add lock back to Smarthings Z-Wave Network
Day 3: Batteries dead. Install new batteries. Exclude lock from Smarthings. Check fitment of lock bolt into door jam. Applied lipstick to bolt edges and face. Confirmed lock bolt does not rub in door frame. Did NOT reconnect to Smartthings.
Day 4: batteries dead.
I have reviewed the historical logs for the device in the IDE, and the live log to ensure no recurring commands were being sent by the hub that could be causing the drain. I would never see any commands/action between using the lock the prior night, then in the morning a statement that the battery was 0% and too low to operate.
I don’t think it’s Smarthings causing the issue, but I am at a loss as to what it could be. The fitment into the door jam and door looks fine. I wanted to check in here to see if anyone had run into this issue. I have also emailed Schlage customer support.
Appreciate any help you have.
