Have you checked the results by making queries to the SmartThings API? For example:
List the devices to get some details like the
deviceIDthat is needed for other requests
https://api.smartthings.com/v1/devices -
Get the device’s capabilities status:
https://api.smartthings.com/v1/devices/device-id/status
You just need to get a Personal Access Token and use it as authorization. This is an example using Postman:
What you can do with the device depends on the available capabilities in it, if it includes the execute, there are some commands that can help you with other actions. For example:
- Here’s a command used in an AC device to turn on/off the screen light
- Also, I found this thread where the integration of another model of the Samsung soundbar is discussed. There could be useful information…
Soundbar HW-N850 Integration
