Margaret_P
(margaretpogue@kokomo.eu)
June 30, 2017, 1:48pm
1
I want to set up a rule, say for instance if there is no events on a motion sensor within a specific time period and then if that rule was brokedn, I would like to display it on the dashboard. Is that possible?
Yes possible but thing can get kinda weird.
Create virtual Switch (this will be on your dashboard)
Use webCoRE to create your rule to turn on your virtual switch if no motion for specific time period. If motion, then turn off your switch.
The bit and pieces are there.
SwitchMania - get here
Create, Control, and Use virtual switches from a single Parent App. No need to use IDE. Allows you to replace dozens of SmartApps with just 1! And if you decide that you no longer need a virtual switch (and/or the link to a Routine), then SwitchMania App deletes it.
SwitchMania - is the parent app.
It controls 2 types of child apps:
(1) My Virtual Switch Creator - which creates virtual (on/off or momentary) switches and
(2) My Switch Calls Routines App - which links a switch with a Routine (Hello Home) when a switch is turned on or off.
You need to install all 3 apps in the IDE.
To have SwitchMania be able to create Virtual Momentary Button Device, you also need to install SmartThings’ “Momentary Button Tile” in the IDE.
Instructions:
The first page of …
Continuing the webCoRE development cycle, we’ve now reached Beta Milestone 2. This milestone will focus on adding missing (important) features, bug fixes, and performance improvement. Things should be smoother now, with less chances of breaking during updates.
And now, again, the warnings:
WARNING #1
The legal boring stuff. This software is free to use, modify, distribute, install on a potato, anything you wish to do with it. As it happens, by using it, you must understand that I cannot be held responsible for anything that stems from the use of this software.
WARNING #2 This software is currently in a BETA release stage. If you don’t know what that means, PLEASE read this !
WARNING #3
If you see any white text on a red banner reading “DO NOT SHARE WITH ANYONE”, it is probably best yo…
ady624
( I hate Mondays)
June 30, 2017, 3:33pm
3
there is also an upcoming feature called “followed by” or rather, “not followed by” - so you can simplify that logic - but I am still working on development of said feature.
Margaret_P
June 30, 2017, 3:50pm
4
Thank you for your suggestion cuboy29
Margaret_P
June 30, 2017, 3:51pm
5
Brilliant, thank you. can you let me know when its ready please ady624
Best bet is probably to keep an eye on the posts in the CoRE subcategory.
https://community.smartthings.com/c/smartapps/core
Margaret_P
July 6, 2017, 3:56pm
7
Will do thank you marktheknife
