Hi all, I’ve improved upon Elfege’s device type to make a larger state machine out of the Roomba virtual switch so that it more closely follows the iRobot App experience.
Here is my unpublished github repo and here is the code block for copy/paste consumption:
Update 1: Included a ‘bin full’ status
Update 2: More error handling, included some additional valueTile, made pollingInterval a setting (default - 4min)
Update 3: Added the Consumable capability in order to allow CORE SmartApps to be used for notifications!
* Roomba 9xx - Virtual Switch
* Copyright 2016 Steve-Gregory
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Roomba 9xx - Virtual Switch", namespace: "Steve-Gregory", author: "Steve-Gregory") {
capability "Switch"
capability "Refresh"
capability "Polling"
capability "Consumable"
capability "Configuration"
command "dock"
command "refresh"
command "resume"
command "pause"
attribute "batteryLevel", "number"
attribute "totalJobs", "number"
attribute "totalJobHrs", "number"
attribute "headline", "string"
attribute "robotName", "string"
attribute "preferences_set", "string"
attribute "status", "string"
// simulator metadata
simulator {
//Preferences
preferences {
section("Roomba Credentials") {
input title: "Roomba Credentials", description: "The username/password can be retrieved via node.js & dorita980", displayDuringSetup: true, type: "paragraph", element: "paragraph"
input "roomba_username", "text", title: "Roomba username/blid", required: true, displayDuringSetup: true
input "roomba_password", "password", title: "Roomba password", required: true, displayDuringSetup: true
input "roomba_host", "string", title:"Roomba Host (Default: Use the Cloud)", defaultValue:""
section("Misc.") {
input title: "Polling Interval", description: "This feature allows you to change the frequency of polling for the robot in minutes (1-59)", displayDuringSetup: true, type: "paragraph", element: "paragraph"
input "pollInterval", "number", title: "Polling Interval", description: "Change polling frequency (in minutes)", defaultValue:4, range: "1..59", required: true, displayDuringSetup: true
// Settings updated
def updated() {
//log.debug "Updated settings ${settings}..
schedule("0 0/${settings.pollInterval} * * * ?", poll) // 4min polling is normal for irobots
poll()
// Configuration
def configure() {
log.debug "Configuring.."
poll()
//Consumable
def setConsumableStatus(statusString) {
log.debug "User requested setting the Consumable Status - ${statusString}"
def status = device.latestValue("status")
log.debug "Setting value based on last roomba state - ${status}"
if(status == "bin-full") {
return "maintenance_required"
} else {
return "good"
//Refresh
def refresh() {
log.debug "Executing 'refresh'"
poll()
//Polling
def poll() {
log.debug "Polling for status ----"
sendEvent(name: "headline", value: "Polling the API", displayed: false)
state.RoombaCmd = "getStatus"
apiGet()
// UI tile definitions
tiles {
multiAttributeTile(name:"CLEAN", type:"lighting", width: 6, height: 4, canChangeIcon: true) {
tileAttribute("device.status", key: "PRIMARY_CONTROL") {
attributeState "error", label: 'Error', icon: "st.switches.switch.off", backgroundColor: "#bc2323" // No action allowed here
attributeState "bin-full", label: 'Bin Full', icon: "st.switches.switch.off", backgroundColor: "#bc2323" // No action allowed here
attributeState "docked", label: 'Start Clean', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff", nextState: "starting"
attributeState "docking", label: 'Docking', icon: "st.switches.switch.off", backgroundColor: "#ffa81e" // No action allowed here
attributeState "starting", label: 'Starting Clean', icon: "st.switches.switch.off", backgroundColor: "#ffffff"
attributeState "cleaning", label: 'Stop Clean', action: "stop", icon: "st.switches.switch.on", backgroundColor: "#79b821"
attributeState "pausing", label: 'Stop Clean', icon: "st.switches.switch.on", backgroundColor: "#79b821" // No action allowed here
attributeState "paused", label: 'Send Home', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821", nextState: "docking"
attributeState "resuming", label: 'Stop Clean', icon: "st.switches.switch.on", backgroundColor: "#79b821" // No action allowed here
tileAttribute("device.headline", key: "SECONDARY_CONTROL") {
attributeState "default", label:'${currentValue}'
tileAttribute("device.batteryLevel", key: "SLIDER_CONTROL") {
standardTile("DOCK", "device.status", width: 2, height: 2) {
state "docked", label: 'Docked', backgroundColor: "#79b821" // No action allowed here
state "docking", label: 'Docking', backgroundColor: "#ffa81e" // No action allowed here
state "starting", label: 'UnDocking', backgroundColor: "#ffa81e" // No action allowed here
state "cleaning", label: 'Not on Dock', backgroundColor: "#ffffff", nextState: "docking"
state "pausing", label: 'Not on Dock', backgroundColor: "#ffffff", nextState: "docking" // No action allowed here
state "paused", label: 'Dock', action: "dock", backgroundColor: "#ffffff", nextState: "docking"
state "resuming", label: 'Not on Dock', backgroundColor: "#ffffff", defaultState: true // No action allowed here
standardTile("PAUSE", "device.status", width: 2, height: 2) {
state "docked", label: 'Pause', backgroundColor: "#ffffff", defaultState: true // No action allowed here
state "docking", label: 'Pause', backgroundColor: "#ffffff" // No action allowed here
state "starting", label: 'Pause', backgroundColor: "#ffffff" // No action allowed here
state "cleaning", label: 'Pause', action: "pause", backgroundColor: "#ffffff"
state "pausing", label: 'Pausing..', backgroundColor: "#79b821" // No action allowed here
state "paused", label: 'Paused', backgroundColor: "#79b821" // No action allowed here
state "resuming", label: 'Pause', backgroundColor: "#ffffff" // No action allowed here
standardTile("RESUME", "device.status", width: 2, height: 2) {
state "docked", label: 'Resume', backgroundColor: "#ffffff", defaultState: true // No action allowed here
state "docking", label: 'Resume', backgroundColor: "#ffffff" // No action allowed here
state "starting", label: 'Resume', backgroundColor: "#ffffff" // No action allowed here
state "cleaning", label: 'Resume', backgroundColor: "#ffffff" // No action allowed here
state "pausing", label: 'Resume', backgroundColor: "#79b821" // No action allowed here
state "paused", label: 'Resume', action: "resume", backgroundColor: "#ffffff"
state "resuming", label: 'Resuming..', backgroundColor: "#79b821" // No action allowed here
standardTile("refresh", "device.status", width: 6, height: 2, decoration: "flat") {
state "default", label:'Refresh', action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("job_count", "device.totalJobs", width: 3, height: 1, decoration: "flat") {
state "default", label:'Number of Cleaning Jobs:\n${currentValue} jobs'
valueTile("job_hr_count", "device.totalJobHrs", width: 3, height: 1, decoration: "flat") {
state "default", label:'Total Job Time:\n${currentValue} hours'
valueTile("current_job_time", "device.runtimeMins", width: 3, height: 1, decoration: "flat") {
state "default", label:'Current Job Runtime:\n${currentValue} minutes'
main "CLEAN"
details(["STATUS",
"CLEAN", "DOCK", "PAUSE", "RESUME",
"refresh", "job_count", "job_hr_count", "current_job_time"])
// Switch methods
def on() {
log.debug "On based on state - ${status}"
if(status == "paused") {
resume()
} else {
start()
def off() {
log.debug "Off based on state - ${status}"
dock()
} else {
stop()
// Actions
def start() {
sendEvent(name: "status", value: "starting")
state.RoombaCmd = "start"
apiGet()
runIn(30, poll)
def stop() {
sendEvent(name: "status", value: "stopping")
state.RoombaCmd = "stop"
apiGet()
runIn(30, poll)
def dock() {
sendEvent(name: "status", value: "docking")
state.RoombaCmd = "dock"
apiGet()
runIn(30, poll)
def pause() {
sendEvent(name: "status", value: "pausing")
state.RoombaCmd = "pause"
apiGet()
runIn(30, poll)
def resume() {
sendEvent(name: "status", value: "resuming")
state.RoombaCmd = "resume"
apiGet()
runIn(30, poll)
// API methods
def parse(description) {
def msg = parseLanMessage(description)
def headersAsString = msg.header // => headers as a string
def headerMap = msg.headers // => headers as a Map
def body = msg.body // => request body as a string
def status = msg.status // => http status code of the response
def json = msg.json // => any JSON included in response body, as a data structure of lists and maps
def xml = msg.xml // => any XML included in response body, as a document tree structure
def data = msg.data // => either JSON or XML in response body (whichever is specified by content-type header in response)
def apiGet() {
def request_query = ""
def request_host = ""
def encoded_str = "${roomba_username}:${roomba_password}".bytes.encodeBase64()
//Handle prefrences
if("${roomba_host}" == "" || "${roomba_host}" == "null") {
request_host = "https://irobot.axeda.com"
} else {
log.debug "Using Roomba Host: ${roomba_host}"
request_host = "${roomba_host}"
//Validation before calling the API
if(!roomba_username || !roomba_password) {
def new_status = "Username/Password not set. Configure required before using device."
sendEvent(name: "headline", value: new_status, displayed: false)
sendEvent(name: "preferences_set", value: "missing", displayed: false)
return
} else if(state.preferences_set != "missing") {
sendEvent(name: "preferences_set", value: "ready", displayed: false)
state.AssetID = "ElPaso@irobot!${roomba_username}"
state.Authorization = "${encoded_str}"
// Path (No changes required)
def request_path = "/services/v1/rest/Scripto/execute/AspenApiRequest"
// Query manipulation
if( state.RoombaCmd == "getStatus" || state.RoombaCmd == "accumulatedHistorical" || state.RoombaCmd == "missionHistory") {
request_query = "?blid=${roomba_username}&robotpwd=${roomba_password}&method=${state.RoombaCmd}"
} else {
request_query = "?blid=${roomba_username}&robotpwd=${roomba_password}&method=multipleFieldSet&value=%7B%0A%20%20%22remoteCommand%22%20:%20%22${state.RoombaCmd}%22%0A%7D"
def requestURI = "${request_host}${request_path}${request_query}"
def httpRequest = [
method:"GET",
uri: "${requestURI}",
headers: [
'User-Agent': 'aspen%20production/2618 CFNetwork/758.3.15 Darwin/15.4.0',
Accept: '*/*',
'Accept-Language': 'en-us',
'ASSET-ID': state.AssetID,
try {
httpGet(httpRequest) { resp ->
resp.headers.each {
log.debug "${it.name} : ${it.value}"
log.debug "response contentType: ${resp.contentType}"
log.debug "response data: ${resp.data}"
parseResponseByCmd(resp, state.RoombaCmd)
} catch (e) {
log.error "something went wrong: $e"
def parseResponseByCmd(resp, command) {
//Parsing
def data = resp.data
if(command == "getStatus") {
setStatus(data)
} else if(command == "accumulatedHistorical" ) {
//readSummaryInfo -- same as getStatus but easier to parse
} else if(command == "missionHistory") {
//readMissionHistory -- get results about last 30 jobs -- Out of scope for device-type?
def setStatus(data) {
//TODO: Mine other data here later? add support for "percent completion"?
def rstatus = data.robot_status
def robotName = data.robotName
def mission = data.mission
def runstats = data.bbrun
def cschedule = data.cleanSchedule
def pmaint = data.preventativeMaintenance
def robot_status = new groovy.json.JsonSlurper().parseText(rstatus)
def robot_history = new groovy.json.JsonSlurper().parseText(mission)
def runtime_stats = new groovy.json.JsonSlurper().parseText(runstats)
def schedule = new groovy.json.JsonSlurper().parseText(cschedule)
def maintenance = new groovy.json.JsonSlurper().parseText(pmaint)
log.debug "Robot Status = ${robot_status}"
log.debug "Robot History = ${robot_history}"
log.debug "Runtime stats= ${runtime_stats}"
log.debug "Robot schedule= ${schedule}"
log.debug "Robot Maintenance= ${maintenance}"
def current_cycle = robot_status['cycle']
def current_charge = robot_status['batPct']
def current_phase = robot_status['phase']
def num_mins_running = robot_status['mssnM']
def flags = robot_status['flags'] // Unknown what 'Flags' 0/1/2/5 mean?
def readyCode = robot_status['notReady']
def num_cleaning_jobs = robot_history['nMssn']
def num_dirt_detected = runtime_stats['nScrubs']
def total_job_time = runtime_stats['hr']
def new_status = get_robot_status(current_phase, current_cycle, current_charge, readyCode)
def roomba_value = get_robot_enum(current_phase, readyCode)
log.debug("Robot updates -- ${roomba_value} + ${new_status}")
//Set the state object
if(roomba_value == "cleaning") {
state.switch = "on"
} else {
state.switch = "off"
state.consumableStatus = "maintenance_required"
} else {
state.consumableStatus = "good"
//send events, display final event
sendEvent(name: "robotName", value: robotName, displayed: false)
sendEvent(name: "totalJobHrs", value: total_job_time, displayed: false)
sendEvent(name: "totalJobs", value: num_cleaning_jobs, displayed: false)
sendEvent(name: "runtimeMins", value: num_mins_running, displayed: false)
sendEvent(name: "batteryLevel", value: current_charge, displayed: false)
sendEvent(name: "status", value: roomba_value)
sendEvent(name: "switch", value: state.switch)
sendEvent(name: "consumableStatus", value: state.consumableStatus)
def get_robot_enum(current_phase, readyCode) {
if(readyCode != 0) {
if(readyCode == 16) {
return "bin-full"
} else {
return "error"
} else if(current_phase == "charge") {
return "docked"
} else if(current_phase == "hmUsrDock") {
return "docking"
} else if(current_phase == "pause" || current_phase == "stop") {
return "paused"
} else if(current_phase == "run") {
return "cleaning"
} else {
//"Stuck" phase falls into this category.
log.error "Unknown phase - Raw 'robot_status': ${status}. Add to 'get_robot_enum'"
return "error"
def parse_not_ready_status(readyCode) {
def robotName = device.latestValue("robotName")
return "${robotName} bin is full. Empty bin to continue."
} else if(readyCode == 7) {
return "${robotName} is not upright. Place robot on flat surface to continue."
} else if (readyCode == 1) {
return "${robotName} is stuck. Move robot to continue."
} else {
return "${robotName} returned notReady=${readyCode}. See iRobot app for details."
def get_robot_status(current_phase, current_cycle, current_charge, readyCode) {
log.debug "Enter get_robot_status"
return parse_not_ready_status(readyCode)
if (current_charge == 100) {
return "${robotName} is Docked/Fully Charged"
} else {
return "${robotName} is Docked/Charging"
return "${robotName} is returning home"
return "${robotName} is cleaning (${current_cycle} cycle)"
return "Paused - 'Dock' or 'Resume'?"
log.error "Unknown phase - ${current_phase}."
return "Error - refresh to continue. Code changes required if problem persists."
Here are some screenshots of the app in action:
Switch (Text alternates between status’ and 'battery level’
Running roomba
Pausing Roomba
Docking Roomba
Docking Roomba via master-button (doesn’t always work)
Recent Activity
Settings
CoRE SmartApp integration via Consumable Capability:
ToDo before release:
- Handle common errors (Bin full, stuck, “not upright”)
- CoRE SmartApp example for ‘bin full’ notifications
- Work on “refresh after actions” Update:30sec after running command, API will poll, in addition to the schedule()
poll configurable in settings, this should work for most people
- Work on the main button being able to start/pause/dock Update: Fixed
- Use ‘password’ input for the password in preferences
- Include historical information as valueTile
- Including settings manipulation from the device
#Notes for future contributions/contributors:
Including Settings manipulation: (API scraped from iRobot using Fiddler+proxy)
#Edge cleaning OFF
blid=...&robotpwd=...&method=multipleFieldSet&value={"twoPass":0,"openOnly":1,"schedHold":0,"manualUpdate":0,"carpetBoost":0,"binPause":0,"vacHigh":0,"noPP":0,"ecoCharge":0,"noAutoPasses":0}
#Edge Cleaning ON
blid=...&robotpwd=...&method=multipleFieldSet&value={"twoPass":0,"openOnly":0,"schedHold":0,"manualUpdate":0,"carpetBoost":0,"binPause":0,"vacHigh":0,"noPP":0,"ecoCharge":0,"noAutoPasses":0}
#Finish cleaning when bin is full
blid=...&robotpwd=...&method=multipleFieldSet&value={"twoPass":0,"openOnly":0,"schedHold":0,"manualUpdate":0,"carpetBoost":0,"binPause":1,"vacHigh":0,"noPP":0,"ecoCharge":0,"noAutoPasses":0}
#Don't finish job, wait for bin to be emptied, then press clean to resume
#Cleaning passes
##One pass
blid=...&robotpwd=...&method=multipleFieldSet&value={"twoPass":0,"openOnly":0,"schedHold":0,"manualUpdate":0,"carpetBoost":0,"binPause":0,"vacHigh":0,"noPP":0,"ecoCharge":0,"noAutoPasses":1}
##Two pass
blid=...&robotpwd=...&method=multipleFieldSet&value={"twoPass":1,"openOnly":0,"schedHold":0,"manualUpdate":0,"carpetBoost":0,"binPause":0,"vacHigh":0,"noPP":0,"ecoCharge":0,"noAutoPasses":1}
##Automatic
#Carpet Boost
##Automatic
blid=...&robotpwd=...&method=multipleFieldSet&value={"twoPass":0,"openOnly":0,"schedHold":0,"manualUpdate":0,"carpetBoost":0,"binPause":0,"vacHigh":0,"noPP":0,"ecoCharge":0,"noAutoPasses":0}##Performance
blid=...&robotpwd=...&method=multipleFieldSet&value={"twoPass":0,"openOnly":0,"schedHold":0,"manualUpdate":0,"carpetBoost":1,"binPause":0,"vacHigh":1,"noPP":0,"ecoCharge":0,"noAutoPasses":0}
##ECO mode
blid=...&robotpwd=...&method=multipleFieldSet&value={"twoPass":0,"openOnly":0,"schedHold":0,"manualUpdate":0,"carpetBoost":1,"binPause":0,"vacHigh":0,"noPP":0,"ecoCharge":0,"noAutoPasses":0}
# Update cleaning schedule (All days set to "No Cleaning" at 9am)
blid=...&robotpwd=...&method=multipleFieldSet&value={ "cleanSchedule" : { "cycle" : ["none", "none", "none", "none", "none", "none", "none"], "h" : [9, 9, 9, 9, 9, 9, 9], "m" : [0, 0, 0, 0, 0, 0, 0] } }
