So I just got the v2 hub and I am using the new app not the classic and it is fully updated. I was able to add my AV receiver, TV, and door lock but for some reason I cannot add the Ring 2 doorbell.
It gives me an error shown in the photo attached. The ring is on the wifi and I can connect to it using the ring app. I have tried 2 different wifi networks that I have but it was a no go.
Ok, I just tried viewing my Ring via ST and live stream failed. I then opened the Ring app and did a live view successfully. I then tried ST again and it worked. Perhaps try that to see if that helps you?
Well crap. You’ve done everything I can think of. Aside from emailing support and waiting for a long time, I’m not sure what you can do. Perhaps remove the app from ST and try again later? Sorry that I’ve got nothing else for you.
Try removing doorbell in both apps and IDE, and than adding it through classic, and changing it to pro in ide. BTW it needs to be hardwired not on battery.
Well I guess I can forget about it then as I cannot hardwire it. Lennar decided that my new home did not need wires for doorbells hence the reason for the ring 2. Oh well.
So guess what! There must be a big in the android app as I used my wife’s phone, added her to the hub account, and then was able to add the ring through the iPhone app. Go figure!
