Remove Device Button Missing
I am no longer seeing the remove device option in the app. Checked under Edit (where I think it was), Settings, Driver, and Information menus for a specific device.
Long press on the device tile.
Same with deleting Routines. Long press on the Routine name.
Right, although there’s still a delete option within the Routine detail page as well (at least on iOS there is).
Yeah, I guess the long press is more of a short-cut where it’s a necessity for device deletion.
  • There is also the option to remove a device when you are in a room (where the device is located) … tap on 3 dots and select Remove device
  • API Browser+
