Mike responded to me that it is OK for me to share. I am using this DTH for my ZMF-80 and it works fine for me. However, Mike DOES NOT SUPPORT this code anymore and my programming knowledge is limited, so please use at your own risk.
/* Remotec ZFM-80 specific device V1.2
* Variation of the stock SmartThings Relay Switch
* --auto re-configure after setting preferences
* --preference settings for switch type and automatic shutoff features.
* Mike Maxwell
* madmax98087@yahoo.com
* 2015-02-16
change log
2015-02-16 added delay between configuration changes, helps with devices further away from the hub.
2015-02-21 fixed null error on initial install
metadata {
definition (name: "remotecZFM80", namespace: "mmaxwell", author: "mike maxwell") {
capability "Actuator"
capability "Switch"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Relay Switch"
fingerprint deviceId: "0x1003", inClusters: "0x20, 0x25, 0x27, 0x72, 0x86, 0x70, 0x85"
preferences {
input name: "param1", type: "enum", title: "Set external switch mode:", description: "Switch type", required: true, options:["Disabled","Momentary NO","Momentary NC","Toggle NO","Toggle NC"]
input name: "param2", type: "enum", title: "Auto shutoff minutes:", description: "Minutes?", required: false, options:["Never","1","5","30","60","90","120","240"]
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch","refresh"])
def installed() {
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x70: 1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result?.name == 'hail' && hubFirmwareLessThan("000.011.00602")) {
result = [result, response(zwave.basicV1.basicGet())]
log.debug "Was hailed: requesting state update"
} else {
log.debug "Parse returned ${result?.descriptionText}"
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
//def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
// def value = "when off"
// if (cmd.configurationValue[0] == 1) {value = "when on"}
// if (cmd.configurationValue[0] == 2) {value = "never"}
// [name: "indicatorStatus", value: value, display: false]
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
[name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (state.manufacturer != cmd.manufacturerName) {
updateDataValue("manufacturer", cmd.manufacturerName)
final relays = [
//[manufacturerId:0x0113, productTypeId: 0x5246, productId: 0x3133, productName: "Evolve LFM-20"],
//[manufacturerId:0x0113, productTypeId: 0x5246, productId: 0x3133, productName: "Linear FS20Z-1"],
[manufacturerId:0x5254, productTypeId: 0x8000, productId: 0x0002, productName: "Remotec ZFM-80"]
def productName = null
for (it in relays) {
if (it.manufacturerId == cmd.manufacturerId && it.productTypeId == cmd.productTypeId && it.productId == cmd.productId) {
productName = it.productName
break
if (productName) {
//log.debug "Relay found: $productName"
updateDataValue("productName", productName)
else {
//log.debug "Not a relay, retyping to Z-Wave Switch"
setDeviceType("Z-Wave Switch")
[name: "manufacturer", value: cmd.manufacturerName]
// Handles all Z-Wave commands we aren't interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
def refresh() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
//capture preference changes
def updated() {
//log.debug "before settings: ${settings.inspect()}, state: ${state.inspect()}"
//"Disabled","Momentary NO","Momentary NC","Toggle NO","Toggle NC"
//external switch function settings
def Short p1 = 0
switch (settings.param1) {
case "Disabled":
p1 = 0
break
case "Momentary NO":
p1 = 1
break
case "Momentary NC":
p1 = 2
break
case "Toggle NO":
p1 = 3
break
case "Toggle NC":
p1 = 4
break
//auto off
def Short p2 = 0
if ("${settings.param2}" == "Never") {
p2 = 0
} else {
p2 = (settings.param2 ?: 0).toInteger()
if (p1 != state.param1) {
state.param1 = p1
return response(zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, configurationValue: [p1]).format())
if (p2 != state.param2) {
state.param2 = p2
if (p2 == 0) {
return response (delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, configurationValue: [0]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, configurationValue: [0]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 4, size: 1, configurationValue: [0]).format()
} else {
zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, configurationValue: [p2]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, configurationValue: [232]).format(),
//log.debug "after settings: ${settings.inspect()}, state: ${state.inspect()}"
def configure() {
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, configurationValue: [3]).format(),
