Dennis,
I had no idea (and still very little now even) about association groups either. I found it in the ZTS’s owners manual:
I figured that is why my thermostats weren’t registering the auto reports. I read somewhere in the Smartthings support docs that the hub auto associates to group 1 so this helped me identify the problem. I’m glad you didn’t have this problem and not sure why yours just worked.
Yes, I just added the association command to the configure function and put a button in there to execute it as well as the config parameters I wanted to set. I thought about expanding on your configuration code for all the other thermostat settings but I have concluded that I probably won’t be changing any of the settings again and if I need to I’ll just go into the device code and put it in the config section again.
I too know very little about Smartthings as I have only had my Hub since Christmas and its my first dive into home automation. I feel like I’m fumbling around in the dark but have managed to get most of my stuff working. I’m with you regarding taking the time to learn more about this stuff. As long as I can get my stuff to work for the most part, I’m happy. The community forums have been a big help to me.
Here is the code for the Device Handler with the buttons (The sliders are way too sensitive for me). Got it from another user on these forums and changed a few things related to the configuration I mentioned above. Hope this helps:
/* Better-Thermostat.device.groovy
* Variation of the stock SmartThings "Zwave-Thermostat"
* Device type removes the sliders and replaces them with incremental
* up and down buttons on each side of the heating and cooling setpoints.
* To use you must have IDE access on your acount. Add a new device
* type and add the custom commands:
* heatLevelUp
* heatLevelDown
* coolLevelUp
* coolLevelDown
* switchMode
* switchFanMode
* Replace the starter code with this code and save the file. Go into
* "My devices" and select the thermostat you want to change. Select "Edit"
* and then change the "Type" to use this device type.
* Happy Hacking!
* twack@wackware.net
* 20140209
metadata {
// Automatically generated. Make future change here.
definition (name: "ZTS-110 Z-Wave Thermostat (Tim)", author: "twack@wackware.net + Tim") {
capability "Temperature Measurement"
capability "Refresh"
capability "Thermostat"
capability "Configuration"
capability "Polling"
command "heatLevelUp"
command "heatLevelDown"
command "coolLevelUp"
command "coolLevelDown"
command "switchMode"
command "switchFanMode"
//fingerprint deviceId: "0x1001"
//fingerprint inClusters: "0x25,0x27,0x86,0x72", manufacturer: "Remotec", model: "ZTS-110"
// simulator metadata
simulator {
status "off" : "command: 4003, payload: 00"
status "heat" : "command: 4003, payload: 01"
status "cool" : "command: 4003, payload: 02"
status "auto" : "command: 4003, payload: 03"
status "fanAuto" : "command: 4403, payload: 00"
status "fanOn" : "command: 4403, payload: 01"
status "fanCirculate" : "command: 4403, payload: 06"
status "heat 60" : "command: 4303, payload: 01 01 3C"
status "heat 68" : "command: 4303, payload: 01 01 44"
status "heat 72" : "command: 4303, payload: 01 01 48"
status "cool 72" : "command: 4303, payload: 02 01 48"
status "cool 76" : "command: 4303, payload: 02 01 4C"
status "cool 80" : "command: 4303, payload: 02 01 50"
status "temp 58" : "command: 3105, payload: 01 22 02 44"
status "temp 62" : "command: 3105, payload: 01 22 02 6C"
status "temp 70" : "command: 3105, payload: 01 22 02 BC"
status "temp 74" : "command: 3105, payload: 01 22 02 E4"
status "temp 78" : "command: 3105, payload: 01 22 03 0C"
status "temp 82" : "command: 3105, payload: 01 22 03 34"
status "idle" : "command: 4203, payload: 00"
status "heating" : "command: 4203, payload: 01"
status "cooling" : "command: 4203, payload: 02"
status "fan only" : "command: 4203, payload: 03"
status "pending heat" : "command: 4203, payload: 04"
status "pending cool" : "command: 4203, payload: 05"
status "vent economizer": "command: 4203, payload: 06"
// reply messages
reply "2502": "command: 2503, payload: FF"
tiles {
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'${currentValue}°', unit:'F',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
standardTile("mode", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
state "off", label:'', action:"switchMode", icon:"st.thermostat.heating-cooling-off"
state "heat", label:'', action:"switchMode", icon:"st.thermostat.heat"
state "cool", label:'', action:"switchMode", icon:"st.thermostat.cool"
state "auto", label:'', action:"switchMode", icon:"st.thermostat.auto"
standardTile("fanMode", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
state "fanAuto", label:'', action:"switchFanMode", icon:"st.thermostat.fan-auto"
state "fanOn", label:'', action:"switchFanMode", icon:"st.thermostat.fan-on"
state "fanCirculate", label:' ', action:"switchFanMode", icon:"st.thermostat.fan-circulate"
valueTile("heatingSetpoint", "device.heatingSetpoint", inactiveLabel: false, decoration: "flat") {
state "heat", label:'${currentValue}° heat', unit:"F", backgroundColor:"#ffffff"
valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false, decoration: "flat") {
state "cool", label:'${currentValue}° cool', unit:"F", backgroundColor:"#ffffff"
standardTile("refresh", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
state "default", action:"polling.poll", icon:"st.secondary.refresh"
standardTile("heatLevelUp", "device.heatingSetpoint", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state "heatLevelUp", label:' ', action:"heatLevelUp", icon:"st.thermostat.thermostat-up"
standardTile("heatLevelDown", "device.heatingSetpoint", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state "heatLevelDown", label:' ', action:"heatLevelDown", icon:"st.thermostat.thermostat-down"
standardTile("coolLevelUp", "device.heatingSetpoint", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state "coolLevelUp", label:' ', action:"coolLevelUp", icon:"st.thermostat.thermostat-up"
standardTile("coolLevelDown", "device.heatingSetpoint", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state "coolLevelDown", label:' ', action:"coolLevelDown", icon:"st.thermostat.thermostat-down"
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main "temperature"
details(["temperature", "mode", "fanMode", "heatLevelDown", "heatingSetpoint", "heatLevelUp", "coolLevelDown", "coolingSetpoint", "coolLevelUp", "refresh", "configure"])
def coolLevelUp(){
int nextLevel = device.currentValue("coolingSetpoint") + 1
if( nextLevel > 99){
nextLevel = 99
log.debug "Setting cool set point up to: ${nextLevel}"
setCoolingSetpoint(nextLevel)
def coolLevelDown(){
int nextLevel = device.currentValue("coolingSetpoint") - 1
if( nextLevel < 50){
nextLevel = 50
log.debug "Setting cool set point down to: ${nextLevel}"
def heatLevelUp(){
int nextLevel = device.currentValue("heatingSetpoint") + 1
if( nextLevel > 90){
nextLevel = 90
log.debug "Setting heat set point up to: ${nextLevel}"
setHeatingSetpoint(nextLevel)
def heatLevelDown(){
int nextLevel = device.currentValue("heatingSetpoint") - 1
if( nextLevel < 40){
nextLevel = 40
log.debug "Setting heat set point down to: ${nextLevel}"
def parse(String description)
def map = createEvent(zwaveEvent(zwave.parse(description, [0x42:1, 0x43:2, 0x31: 3, 0x70: 1])))
if (!map) {
return null
def result = [map]
if (map.isStateChange && map.name in ["heatingSetpoint","coolingSetpoint","thermostatMode"]) {
def map2 = [
unit: "F"
if (map.name == "thermostatMode") {
updateState("lastTriedMode", map.value)
if (map.value == "cool") {
map2.value = device.latestValue("coolingSetpoint")
log.info "THERMOSTAT, latest cooling setpoint = ${map2.value}"
else {
map2.value = device.latestValue("heatingSetpoint")
log.info "THERMOSTAT, latest heating setpoint = ${map2.value}"
else {
def mode = device.latestValue("thermostatMode")
log.info "THERMOSTAT, latest mode = ${mode}"
if ((map.name == "heatingSetpoint" && mode == "heat") || (map.name == "coolingSetpoint" && mode == "cool")) {
map2.value = map.value
map2.unit = map.unit
if (map2.value != null) {
log.debug "THERMOSTAT, adding setpoint event: $map"
result << createEvent(map2)
} else if (map.name == "thermostatFanMode" && map.isStateChange) {
updateState("lastTriedFanMode", map.value)
log.debug "Parse returned $result"
result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.thermostatsetpointv2.ThermostatSetpointReport cmd)
def map = [:]
map.value = cmd.scaledValue.toString()
map.unit = cmd.scale == 1 ? "F" : "C"
map.displayed = false
switch (cmd.setpointType) {
case 1:
map.name = "heatingSetpoint"
break;
case 2:
map.name = "coolingSetpoint"
break;
default:
return [:]
// So we can respond with same format
state.size = cmd.size
state.scale = cmd.scale
state.precision = cmd.precision
map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv3.SensorMultilevelReport cmd)
def map = [:]
map.value = cmd.scaledSensorValue.toString()
map.name = "temperature"
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport cmd)
def map = [:]
switch (cmd.operatingState) {
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_IDLE:
map.value = "idle"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_HEATING:
map.value = "heating"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_COOLING:
map.value = "cooling"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_FAN_ONLY:
map.value = "fan only"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_HEAT:
map.value = "pending heat"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_COOL:
map.value = "pending cool"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_VENT_ECONOMIZER:
map.value = "vent economizer"
break
map.name = "thermostatOperatingState"
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport cmd) {
def map = [:]
switch (cmd.mode) {
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_OFF:
map.value = "off"
break
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_HEAT:
map.value = "heat"
break
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_COOL:
map.value = "cool"
break
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUTO:
map.value = "auto"
break
map.name = "thermostatMode"
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport cmd) {
def map = [:]
switch (cmd.fanMode) {
case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_AUTO_LOW:
map.value = "fanAuto"
break
case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_LOW:
map.value = "fanOn"
break
case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_CIRCULATION:
map.value = "fanCirculate"
break
map.name = "thermostatFanMode"
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeSupportedReport cmd) {
def supportedModes = ""
if(cmd.off) { supportedModes += "off " }
if(cmd.heat) { supportedModes += "heat " }
if(cmd.cool) { supportedModes += "cool " }
if(cmd.auto) { supportedModes += "auto " }
updateState("supportedModes", supportedModes)
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeSupportedReport cmd) {
def supportedFanModes = ""
if(cmd.auto) { supportedFanModes += "fanAuto " }
if(cmd.low) { supportedFanModes += "fanOn " }
if(cmd.circulation) { supportedFanModes += "fanCirculate " }
updateState("supportedFanModes", supportedFanModes)
def updateState(String name, String value) {
state[name] = value
device.updateDataValue(name, value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
log.debug "Zwave event received: $cmd"
log.warn "Unexpected zwave command $cmd"
// Command Implementations
def poll() {
delayBetween([
zwave.sensorMultilevelV3.sensorMultilevelGet().format(), // current temperature
zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 1).format(),
zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 2).format(),
zwave.thermostatModeV2.thermostatModeGet().format(),
zwave.thermostatFanModeV3.thermostatFanModeGet().format(),
zwave.thermostatOperatingStateV1.thermostatOperatingStateGet().format()
/* Config Polling ****Add comma to previous line****
zwave.configurationV1.configurationGet(parameterNumber: 1).format(),
zwave.configurationV1.configurationGet(parameterNumber: 2).format(),
zwave.configurationV1.configurationGet(parameterNumber: 3).format(),
zwave.configurationV1.configurationGet(parameterNumber: 4).format(),
zwave.configurationV1.configurationGet(parameterNumber: 5).format(),
zwave.configurationV1.configurationGet(parameterNumber: 14).format(),
zwave.configurationV1.configurationGet(parameterNumber: 6).format(),
zwave.configurationV1.configurationGet(parameterNumber: 7).format(),
zwave.configurationV1.configurationGet(parameterNumber: 8).format(),
zwave.configurationV1.configurationGet(parameterNumber: 9).format(),
zwave.configurationV1.configurationGet(parameterNumber: 10).format(),
zwave.configurationV1.configurationGet(parameterNumber: 11).format(),
zwave.configurationV1.configurationGet(parameterNumber: 12).format(),
zwave.configurationV1.configurationGet(parameterNumber: 13).format()
], 2300)
def setHeatingSetpoint(degreesF) {
setHeatingSetpoint(degreesF.toDouble())
def setHeatingSetpoint(Double degreesF) {
def p = (state.precision == null) ? 1 : state.precision
delayBetween([
zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 1, scale: 1, precision: p, scaledValue: degreesF).format(),
def setCoolingSetpoint(degreesF) {
setCoolingSetpoint(degreesF.toDouble())
def setCoolingSetpoint(Double degreesF) {
delayBetween([
zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 2, scale: 1, precision: p, scaledValue: degreesF).format(),
def configure() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSupportedGet().format(),
zwave.thermostatFanModeV3.thermostatFanModeSupportedGet().format(),
zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format(),
zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(),
//Tim Code Start ***Don't forget comma on previous line
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, scaledConfigurationValue: 1).format()
//zwave.configurationV1.configurationSet(parameterNumber: 11, size: 1, scaledConfigurationValue: 1).format(),
//zwave.configurationV1.configurationSet(parameterNumber: 13, size: 1, scaledConfigurationValue: 0).format()
//Tim Code End*/
], 2300)
def modes() {
["off", "auto", "heat", "cool"]
def switchMode() {
def currentMode = device.currentState("thermostatMode")?.value
def lastTriedMode = getDataByName("lastTriedMode") ?: currentMode ?: "off"
def supportedModes = getDataByName("supportedModes")
def modeOrder = modes()
def next = { modeOrder[modeOrder.indexOf(it) + 1] ?: modeOrder[0] }
def nextMode = next(lastTriedMode)
if (supportedModes?.contains(currentMode)) {
while (!supportedModes.contains(nextMode) && nextMode != "off") {
nextMode = next(nextMode)
log.debug "Switching to mode: ${nextMode}"
switchToMode(nextMode)
def switchToMode(nextMode) {
if(supportedModes && !supportedModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
if (nextMode in modes()) {
updateState("lastTriedMode", nextMode)
return "$nextMode"()
} else {
log.debug("no mode method '$nextMode'")
def switchFanMode() {
def currentMode = device.currentState("thermostatFanMode")?.value
def lastTriedMode = getDataByName("lastTriedFanMode") ?: currentMode ?: "off"
def supportedModes = getDataByName("supportedFanModes") ?: "fanAuto fanOn"
def modeOrder = ["fanAuto", "fanCirculate", "fanOn"]
while (!supportedModes?.contains(nextMode) && nextMode != "fanAuto") {
switchToFanMode(nextMode)
def switchToFanMode(nextMode) {
def supportedFanModes = getDataByName("supportedFanModes")
if(supportedFanModes && !supportedFanModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
def returnCommand
if (nextMode == "fanAuto") {
returnCommand = fanAuto()
} else if (nextMode == "fanOn") {
returnCommand = fanOn()
} else if (nextMode == "fanCirculate") {
returnCommand = fanCirculate()
} else {
log.debug("no fan mode '$nextMode'")
if(returnCommand) updateState("lastTriedFanMode", nextMode)
returnCommand
def getDataByName(String name) {
state[name] ?: device.getDataValue(name)
def getModeMap() { [
"off": 0,
"heat": 1,
"cool": 2,
"emergency heat": 4
def setThermostatMode(String value) {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[value]).format(),
def getFanModeMap() { [
"auto": 0,
"on": 1,
"circulate": 6
def setThermostatFanMode(String value) {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: fanModeMap[value]).format(),
def off() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 0).format(),
def heat() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 1).format(),
def cool() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 2).format(),
def auto() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 3).format(),
def fanOn() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 1).format(),
def fanAuto() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 0).format(),
def fanCirculate() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 6).format(),
PS I am also using the SmartTiles smartapp to control most of my devices including the thermostats, everything is on one page instead of going into the smartthings app and navigating around to my thermostats, lights etc.
I am in the UK . I tried to set the scale from F to C but the thermostat is responding in F and i am trying to set it in C , hence it never switches on as the temperatures are too low. Is there a hex value to set the scale i.e. to C not F ? thanks
