[RELEASE] Zooz ZAC36 Titan Valve Actuator
There’s a driver available for this device on Zooz’s Edge Driver Channel.
Most of the information below is for the old Groovy Handler which will stop working on 9/30/2022.
This is a device handler for the Zooz ZAC36 Titan Valve Actuator.
Features
  • Valve
  • Water Sensor
  • Temperature Measurement
  • Temperature Alarm
Got an edge driver for this yet? Mine delivers tomorrow.
Sorry, at the moment this isn’t high on the priority list, but that could change if more users request it.
An Edge Driver is available for the ZAC36 so let me know if you’d like an invite to the the Zooz Beta Driver Channel topic.
I would. Thanks Kevin.
Can I get invite to Zooz Beta Driver Channel?
Hi Kevin,
Could I please get an invite to the edge driver?
My zac36 no longer works in SmartThings via QR not pin code setup, and Tech support won’t help unless I try the edge drivers as a last result. Thanks!
Hello Kevin,
I used the ZAC36 Groovy driver for awhile, but found that it caused “Status” issues when the periodic ‘testing’ (Close/Open) occured. I removed all drivers and now I only have limited control/status of the device. Could I get access to your LUA driver so I can perform some testing, and provide feedback?
Thanks,
There’s a driver available for the Zooz ZAC36 Valve Actuator on Zooz’s Edge Driver Channel.
