Try under Menu >
Settings > Linked Services?
thanks for your help, but it is not present in that menu, it remains only in the menu of recommended new routines to add. I don’t know where exactly she resides ![]()
Add Routine > Discover > scroll to bottom to list custom smartapps?
or
IDE > My Locations > smartapps? but doubtful it is there
or
simply wait for ST to remove all groovy stuff ![]()
I have this persistent smartapp visible in the app and also via CLI it results in the smartapps, but the IDE indicates nothing.
How can I delete it?
It is the smartapp of this old application that is no longer supported and the creators are no longer responding. (including the website no longer exists)
@nayelyz I don’t know if you are the right person to contact, if not I apologize, but who should I ask? The assistance in Italy works badly and refers to the general assistance of Samsung which I have already seen in the past not being competent on Smartthings.
Hi, @Diegocampy.
As you already contacted other support without success, I can help you out.
First, please, provide support access to your account to see if I can get the corresponding info from that app and make the request to remove it from your account, does it appear in only one location or in others as well?
Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM
Enable support access to your account:
- Go to the SmartThings Web (my.smartthings.com)
- Log in to your Samsung Account
- Select Menu (⋮) and choose Settings
- Toggle on Account Data Access
- Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
thanks @nayelyz, yes, the email is the same and I have given access to the page you indicated. Thank you
Hi, @Diegocampy.
Checking the details of your account, I see this SmartApp is a Webhook SmartApp.
This means it is one that was registered in the Developer Workspace. Does it appear in the list of those installed?
If not, you can simply:
- Go to the Developer Workspace
- Enter the SmartApp project
- Click on “Unlist from test”. For example:
solved, thanks. Perhaps the developer of that app had done this. I don’t know, but I finally fixed it. Thank you
No one can access your Developer Workspace or create something there unless you give them your credentials. Even if they created a SmartApp through the API, it shouldn’t be appearing in the app because it needs to be deployed to test and that can only be done in the Dev WS…this is weird.
I’m glad you were able to remove it. You can disable the access now ![]()
Sorry @nayelyz days later, this app is back, I see it by searching through API
Using this amazing service that queries API:
I don’t understand where you’re coming from:
in the Developer Workspace I have already deleted all.
Hi, @Diegocampy
Can you provide access again to your account, please? This is odd
Yes @nayelyz , I have try but not change. ![]()
What do you mean? I asked if you could provide support access to your account to see what I can observe on my side, but I still have no access. Could you enable it, please?
I have activated this for a month. thanks, tell me if I can do anything else
