pizzinini
(Pizzinini)
233
For Homebridge installation instructions go here:
You can install the Smartthings plugin via the GUI.
For the SmartThings Smartapp it’s enough if you delete the old Smartapp in the SmartThings app.
Then it is easiest if you use the ST-Community-Installer app to install the new “Homebridge v2” Smartapp.
You then use the new appID and token from the Homebridge Smartapp and enter it in the config of the Homebridge plugin.
After that everything should sync!
