[RELEASE] Fibaro FGS-212 Relay
I’ve got a Fibaro FGS-212 Relay that allows for a single load to be controlled remotely, or via a toggle switch or momentary. I found some DTH’s knocking about for other similar devices, however the FGS-212 lets you set the type of switch you are using.
Personally, I was using a Momentary switch and the FGS-212 is defaulted to use a Toggle switch. I’ve modified the below DTH to allow you to change the switch type.
Note 1: I’m not entirely sure where the base for this DTH came from. I certainly didn’t write the core of it and I found it in my DTH’s from a long time ago. If anyone can find the source for this, let me know so I can credit it. The copyright header says its from Samsung but I’m struggling to locate anything so its provided on an “as is” basis
Note 2: I am by no means a pro coder with Groovy, so it is likely there are a few bugs with this. I know things like the polling don’t get the status of the switch, and I’m not really sure how to get this. Right now, it changes the UI based on the response from the switch when the parameters are changed… Not ideal, so if anyone can improve on this, feel free
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "Fibaro FGS-212 Relay", namespace: "hespg", author: "hespg") {
		capability "Actuator"
		capability "Switch"
		capability "Polling"
		capability "Refresh"
		capability "Sensor"
		capability "Relay Switch"
        capability "Configuration"
        command 'switchToMomentary'
        command 'switchToToggle'
        command 'enableRollerShutter'
        command 'disableRollerShutter'
        attribute "switchType", "string"
        attribute "rollerShutter", "string"
		attribute "label", "string"
		fingerprint deviceId: "0x1001", inClusters: "0x20,0x25,0x27,0x72,0x86,0x70,0x85"
		fingerprint deviceId: "0x1003", inClusters: "0x25,0x2B,0x2C,0x27,0x75,0x73,0x70,0x86,0x72"
	// simulator metadata
	simulator {
		status "on":  "command: 2003, payload: FF"
		status "off": "command: 2003, payload: 00"
		// reply messages
		reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
		reply "200100,delay 100,2502": "command: 2503, payload: 00"
	// tile definitions
	tiles(scale:2) {
		standardTile("switch", "device.switch", width: 6, height: 2, canChangeIcon: true, decoration: "flat") {
			state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00a0dc"
			state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
		standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
        valueTile("switchTypeLabel", "device.switch", width: 2, height: 1) {
    		state 'on', label: 'Button Type'
            state 'off', label: 'Button Type'
        valueTile("refreshLabel", "device.switch", width: 2, height: 1) {
    		state 'on', label: 'Refresh'
            state 'off', label: 'Refresh'
        valueTile("dimmerShutterLabel", "device.switch", width: 2, height: 1) {
    		state 'on', label: 'Dimmer/Shutter'
            state 'off', label: 'Dimmer/Shutter'
        valueTile("autoOffLabel", "device.switch", width: 2, height: 1) {
    		state 'on', label: 'Auto Off'
            state 'off', label: 'Auto Off'
        standardTile("switchTypeTile", "switchType", width: 2, height: 2, decoration: 'flat') {
        	state "momentary", label: "Push", action: "switchToToggle", icon:"https://cdn.rawgit.com/greghesp/fibaro-212-relay/896dc359/icons/Minimize%20Window%20Filled-50.png"
            state "toggle", label: "Toggle", action: "switchToMomentary", icon:"https://cdn.rawgit.com/greghesp/fibaro-212-relay/896dc359/icons/Switch%20On%20Filled-50.png"
        standardTile("rollerShutterTile", "rollerShutter", width: 2, height: 2, decoration: 'flat') {
        	state "Disable", label: "Disabled", action: "enableRollerShutter", icon:"https://cdn.rawgit.com/greghesp/fibaro-212-relay/a503a019/icons/Blind%20Automatic%20Mode-Off.png"
            state "Enable", label: "Enabled", action: "disableRollerShutter", icon:"https://cdn.rawgit.com/greghesp/fibaro-212-relay/a503a019/icons/Blind%20Automatic%20Mode-On.png"
		main "switch"
		details(["switch","switchTypeTile","refresh"])
def installed() {
	zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
	//Runs when device sends update
	def result = null
	def cmd = zwave.parse(description, [0x20: 1, 0x70: 1])
	if (cmd) {
		result = createEvent(zwaveEvent(cmd))
	if (result?.name == 'hail' && hubFirmwareLessThan("000.011.00602")) {
		result = [result, response(zwave.basicV1.basicGet())]
		log.debug "Was hailed: requesting state update"
	} else {
		log.debug "Parse returned ${cmd}"
	return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	log.debug('Basic Report');
    log.debug(cmd)
	[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
    // This runs when SmartThings makes a change
	log.debug('Binary report');
    log.debug(cmd);
	[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
	log.debug('Config Report');
    log.debug(cmd);
	def value = "when off"
    //Setup blind control values here:
    if (cmd.configurationValue[0] == 0) {
    	log.debug('Device is set to Momentary')
        sendEvent(name: "switchType", value: "momentary")
	if (cmd.configurationValue[0] == 1) {
   	 	value = "when on"
    	log.debug('Device is set to Toggle')
        sendEvent(name: "switchType", value: "toggle")
	if (cmd.configurationValue[0] == 2) {value = "never"}
    log.debug "${switchType}"
	[name: "indicatorStatus", value: value, display: false]
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
	log.debug('Hail');
    log.debug(cmd);
	[name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	log.debug('Manufacturer Report');
    log.debug(cmd)
	// Handles all Z-Wave commands we aren't interested in
    //log.debug(cmd)
def on() {
	delayBetween([
		zwave.basicV1.basicSet(value: 0xFF).format(),
		zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
	delayBetween([
		zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
def refresh() {
	delayBetween([
		zwave.switchBinaryV1.switchBinaryGet().format(),
		zwave.manufacturerSpecificV1.manufacturerSpecificGet().format(),
        zwave.manufacturerSpecificV2.manufacturerSpecificGet().format(),
def switchToMomentary() {
		log.debug "Changing Switch Type to Momentary"
        delayBetween([
			zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 14, size: 1, ).format(),
            zwave.configurationV1.configurationGet(parameterNumber: 14).format()
        ], 500)
def switchToToggle() {
		log.debug "Changing Switch Type to Toggle"
        delayBetween([
			zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 14, size: 1, ).format(),
        ], 500)
def enableRollerShutter() {
		log.debug "Shutter function was enabled"
        delayBetween([
			zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 15, size: 1, ).format(),
            zwave.configurationV1.configurationGet(parameterNumber: 15).format()
        ], 500)
def disableRollerShutter() {
		log.debug "Shutter function was disabled"
        delayBetween([
			zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 15, size: 1, ).format(),
        ], 500)
thanks it work perfectly
Hi there,
Sorry to be a pain!
But how do I use this?
I’ve got the device handler selected in the IDE for my device, but the switch is still set to a “toggle” state and not momentary.
My guess is it’s because I haven’t edited the code for the handler, but am not sure how to.
Appreciate any help.
Hey,
I installed your code and works in the app, i only cant find the momentarely state?
Hi!
I have written a new DTH for the Fibaro FGS-212
It allows you to set the switch type.
Best regards,
Jone
