[RELEASE] Enhanced Z-Wave Plus Thermostat Device Handler - Honeywell, GoControl, CT, Linear, Trane, MCO, Remotec
Hi, I have a quick question,
Can I install this app to ST while I am having standard ST Thermostat app installed?
Then basically I will have two thermostat controller apps in my ST.
(I wanted to do that way to make sure I test this app while keeping one working app)
This isn’t an app, it’s a device handler, it provides a mechanism for ST to communicate with the thermostat. So not sure what you’re asking but in general it’s a bad idea to have two apps control one thermostat.
Hi RBoy
Sorry about my lack of understanding. Yes I was referring to the device handler.
I like to add this enhanced device handler to control my GoControl GC-TBZ48L (from Lowes).
As your comment I guess I have to remove Smartthings standard handler and add this device handler to test it out.
hi,
I’ve updated the code of my device handler with new code.
but now my thermostat shows only as ā€œtiles missingā€ in the name.
there is no real name.
also there are no tiles in it.
I’ve created a new device with the new handler. it is also ā€œtiles missingā€
I’ve tried reverting back to the previous version. but same result happened.
what’s happening ? how can I get back my thermostat ?
I see this error in the graph api log :
error java.lang.NullPointerException: Cannot get property 'id' on null object @ line 244
I don’t think you’re using this device handler, there no line 244 with id in it.
I agree.
there is a ā€œunsubscribeā€ command on line 244.
but I get this error.
and when I comment out that line, the error goes off.
so I am using this device handler. but how shall we solve the issue ?
If you’re aren’t seeing this in line 244, you aren’t using this DH (or atleast the latest version).
[value: 44, color: ā€œ#1e9cbbā€],
And if you’re seeing unsubscribe then you aren’t editing a device handler either, it’s a SmartApp.
ok. my bad…
I’ve copied smart app code to the device handler.
but I remember that api was rejecting this. I didnt understand why it didnt reject…
So I’ve got a CT30. When I click Configure, it doesn’t seem to do anything. Is it not supported on my thermostat?
It won’t do anything from a user point of view. It’s only helps reconfigure and reassociate the device.
Is it possible with this device handler to tell my CT30 to just run its schedule through CORE?
edit: To expand on this, I’m setting Cool to very high when I leave, but want it to start running its normal scheduled temp when I get home.
Yes you can do that through CoRE but have you seen this SmartApp which is designed just for that purpose:
I’m seeing the clock getting updated every 15 minutes, looks like the clock set age is not being reset on each refresh / update? I’m on DH version 02.05.03.
That’s because some app or rule is forcing your Thermostat to do force refresh, which resets the age. See the first line of your log
INFO Requesting a refresh
I used to have pollster refreshing the thermostat, but I checked and that hasn’t been enabled in a long time. I don’t see anything else that is set to refresh it on a timer. But still, shouldn’t the Clock set age value be reset to 0 when the clock is set? Seems like it’s always showing 1440.00xx minutes in that, and the battery check time values.
No it’s the reverse, it’s reset to 0 and then updated every 1440 minutes. However if an app force an update/refresh then it sets it expired (1440) which causes it to set the clock.
Bottom line, some app is forcing a refresh on your device which is causing it to set the clock.
Any ideas on tracking down what might be triggering the refrresh?
Edit: Looks like it’s The Google Assistant triggering the refresh. I will try removing the thermostat from google assistant integration and see if that stops the all-too-frequent refreshes.
Mine shows as inactive in IDE. Noticed this when Google Assistant said the Thermostat is offline. Shows on, on the physical thermostat.
How do I change it to ā€œactive?ā€
That means the device has not been communicating with the hub for a while. This is normal in most cases, if you don’t use a device for a few hours it can show as inactive. Just change some settings to force it to communicate with the hub and it’ll show as active. If you can’t change the settings with thermostat then your hub may have lost communication with the thermostat. In such a case hit the reset button the thermostat or you may have to exclude and re pair your thermostat depending up on the condition of your hub/thermostat pairing.
