Device handler for the Elgato Key Light and Key Light Air.
Requires lights with a fixed IP address (configured via device preference). Bonjour auto-discovery is not implemented.
It works! 2 questions…
I have Orbi as router.
This should help with your router question https://www.google.com/search?q=netgear+reserve+ip
Controlling color temp would be possible, I just didn’t need it beyond having it set correctly once. If you want to give it a try coding-wise, the source code I released has a pointer to the reverse-engineering prior-art which does include a color-temp feature.
Wish I knew how to code. Thx for the upload tho!
I’ve just installed the device handler, but somehow can’t get the device to show up in the new SmartThings app. Is there anything special I need to do?
I also tried to add the device from the IDE, which seems to work, but I’m not sure what “Network ID” I’m supposed to enter. I did set the hostname correctly, but the device still won’t connect.
You are an absolute star and have saved my sanity. Being able to control these lights via SmartThings (and thus by, Alexa and Google Assistant), avoiding the flakiness of Bonjour, has meant that I can now reliably control the lights when I need to!
Great job @cramforce !
First of all Thanks @cramforce !
These are the steps I took for it to work
Go to https://graph-na04-useast2.api.smartthings.com/
Open the Smarthings App
Now you should be able to control your KeyLight
I’ve been in a happy place with ST for a bit where everything is in its place and I haven’t had to touch much of late…but I just acquired a couple Elgato lights and had my fingers crossed that somebody like @cramforce had taken on the challenge.
Almost 6 years in and this group never disappoints.
