Osram Lightify CLA 60 W Clear
So, I bought one of these yesterday - https://www.amazon.co.uk/Osram-4052899947238-Lightify-Classic-Plastic/dp/B00YSXBK7M
I can get it to pair and it identifies as:
application: 15
manufacturer: OSRAM
model: Classic A60 W clear - LIGHTIFY
However, it doesn’t like to be called a ’ ZigBee White Color Temperature Bulb’
Has anyone else had any luck? Alternatively, I’m quite happy to write a device handler if I need to - can anyone point me to a good starter on this? (I can write code).
I’m going to be honest here. I’m disappointed by my own google-fu. I clearly haven’t mastered searching these forums. I found and used the device type here:
It now dims and turns on and off but doesn’t have a white colour shift. The box doesn’t mention it but the amazon listing does. Any ideas how to check?
The Amazon listing is wrong,the color temp is fixed at 2700: http://www.osram.com/osram_com/products/led-technology/lightify/lightify-home/lightify-lamps/lightify-classic-a-60-white/index.jsp
Thanks, v. helpful. good thing its at the 2700 end - much nicer :slight_smile:
Silly question but I can’t get my CLA 60 W Clear to register with Smartthings. Is there anything more than using the reset process (off-on 5 seconds, 5 times)?
