Regular ADDON Switch + zwave relay to control single pole lights
Hello, I am wondering if anybody had an experience with any variation of this combo:
https://www.amazon.com/gp/product/B001HSYT3S/ref=oh_aui_detailpage_o06_s01?ie=UTF8&psc=1
combined with
https://www.amazon.com/gp/product/B06Y23DYWV/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
the add-on switches are obviously not capable of handling a real load, I am looking at this solution simply because that style of switch (zwave has been discontinued - http://www.leviton.com/en/products/DZS15-1LZ ) and this seems like the only solution, thanks
I do not tried it but,
I would not expect perfect operation with that combination because that add-on switch has a LED and some related setup instructions, suggesting it is not a strictly dry-contact signal that the DSC26103-ZWUS is expecting on its input.
You can use any dumb (and cheap) wallwitch as input to the DSC26103-ZWUS but but the wallswitch will not have a LED.
Don’t care about the status light it’s more about the “toggle” style of this physical switch vs a traditional paddle.
I do not know about the Leviton switch but aeons can be set to accept both On/Offs and momentary presses.
Hint: search for Mike Maxwell’s Adorne hack.
“Momentary retractive style,” technically.
Leviton Toggle
IMG_4149
Leviton Rocker ( Press the top for on, press the button for off)
IMG_4151
Leviton Momentary Switch ( Press the bottom once, whether you are turning it on or off)
What’s the model number of the last switch you pasted, that’s exactly what I want except that the zwave version has been discontinued and replaced with a traditional rocker - so I want to combine that with a zwave relay, thanks
Ahh I zoomed in that’s the matching switch I was asking about
