I’ve got an Hikvion camera and want to get motion based triggering working. The camera has multiple xml output URL’s to get the status from. In this case I want to use the following url:
[IPADRESS]/IO/outputs/1/status
wich outputs:
XML:
<IOPortStatus xmlns="http://www.hikvision.com/ver10/XMLSchema" version="1.0">
<ioPortID>1</ioPortID>
<ioPortType>output</ioPortType>
<ioState>inactive</ioState>
</IOPortStatus>
With the ioState changes to “active” when motion is detected.
I’ve edited a existing Device handler (created by pstuart’s) to get local video and snapshot working and added some code for the motion detection, but I don’t get it working. My experience in programming is very limited, so I’am really stuck here. I tried to find examples of XML parsing with ST, and motion detection rules, but I can’t find anything that I can apply to this case. Also I did a lot of trial-and-error, but since the output in the log is also limited (doesn’t say anything) I’m really stuck.
It should be that hard, so hopefully the community can help me to get this working (I know if I get the XML parsing working, I will have the basics for writing more device handlers)
This is the code for the Device Handler I’m using now. The motion part(XML parser) is at the bottom of the file.
Device Handler
* Generic IP Camera
* Based on pstuart's Generic Video Camera and Generic Camera Device
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "TEST Camera", namespace: "KiefDelicious", author: "tinlau") {
capability "Image Capture"
capability "Sensor"
capability "Actuator"
capability "Configuration"
capability "Video Camera"
capability "Video Capture"
capability "Refresh"
capability "Switch"
capability "Motion Sensor"
command "start"
attribute "hubactionMode", "string"
preferences {
input("CameraIP", "string", title:"Camera IP Address", description: "Please enter your camera's IP Address", required: false, displayDuringSetup: true)
input("CameraUser", "string", title:"Camera User", description: "Please enter your camera's username", required: false, displayDuringSetup: true)
input("CameraPassword", "string", title:"Camera Password", description: "Please enter your camera's password", required: false, displayDuringSetup: true)
input("CameraRtspPort", "string", title:"Camera RTSP Port", description: "Please enter your camera's RTSP Port", defaultValue: 554 , required: false, displayDuringSetup: true)
input("CameraPort", "string", title:"Camera Port", description: "Please enter your camera's Port", defaultValue: 80 , required: false, displayDuringSetup: true)
input("CameraPath", "string", title:"Camera Path to Image", description: "Please enter the path to the image", defaultValue: "/Streaming/Channels/1/picture", required: false, displayDuringSetup: true)
input("CameraPathVideo", "string", title:"Camera Path to Video", description: "Please enter the path to the video", defaultValue: "/Streaming/Channels/1", required: false, displayDuringSetup: true)
input("CameraAuth", "bool", title:"Does Camera require User Auth?", description: "Please choose if the camera requires authentication (only basic is supported)", defaultValue: true, required: false, displayDuringSetup: true)
input("CameraPostGet", "string", title:"Does Camera use a Post or Get, normally Get?", description: "Please choose if the camera uses a POST or a GET command to retreive the image", defaultValue: "GET", required: false, displayDuringSetup: true)
simulator {
tiles {
multiAttributeTile(name: "videoPlayer", type: "videoPlayer", width: 6, height: 4) {
tileAttribute("device.switch", key: "CAMERA_STATUS") {
attributeState("on", label: "Active", icon: "st.camera.dlink-indoor", action: "switch.off", backgroundColor: "#79b821", defaultState: true)
attributeState("off", label: "Inactive", icon: "st.camera.dlink-indoor", action: "switch.on", backgroundColor: "#ffffff")
attributeState("restarting", label: "Connecting", icon: "st.camera.dlink-indoor", backgroundColor: "#53a7c0")
attributeState("unavailable", label: "Unavailable", icon: "st.camera.dlink-indoor", action: "refresh.refresh", backgroundColor: "#F22000")
tileAttribute("device.errorMessage", key: "CAMERA_ERROR_MESSAGE") {
attributeState("errorMessage", label: "", value: "", defaultState: true)
tileAttribute("device.camera", key: "PRIMARY_CONTROL") {
attributeState("on", label: "Active", icon: "st.camera.dlink-indoor", backgroundColor: "#79b821", defaultState: true)
attributeState("off", label: "Inactive", icon: "st.camera.dlink-indoor", backgroundColor: "#ffffff")
attributeState("unavailable", label: "Unavailable", icon: "st.camera.dlink-indoor", backgroundColor: "#F22000")
tileAttribute("device.startLive", key: "START_LIVE") {
attributeState("live", action: "start", defaultState: true)
tileAttribute("device.stream", key: "STREAM_URL") {
attributeState("activeURL", defaultState: true)
standardTile("take", "device.image", width: 2, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) {
state "take", label: "Take", action: "Image Capture.take", icon: "st.camera.camera", backgroundColor: "#FFFFFF", nextState:"taking"
state "taking", label:'Taking', action: "", icon: "st.camera.take-photo", backgroundColor: "#53a7c0"
state "image", label: "Take", action: "Image Capture.take", icon: "st.camera.camera", backgroundColor: "#FFFFFF", nextState:"taking"
standardTile("refresh", "device.alarmStatus", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
state "refresh", action:"polling.poll", icon:"st.secondary.refresh"
standardTile("blank", "device.image", width: 2, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "blank", label: "", action: "", icon: "", backgroundColor: "#FFFFFF"
standardTile("motion", "device.motionStatus", inactiveLabel: false, decoration: "flat") {
state "off", label: "off", action: "toggleMotion", icon: "st.motion.motion.inactive", backgroundColor: "#FFFFFF"
state "on", label: "on", action: "toggleMotion", icon: "st.motion.motion.active", backgroundColor: "#00ff00"
standardTile("refresh", "device.cameraStatus", inactiveLabel: false, decoration: "flat") {
carouselTile("cameraDetails", "device.image", width: 6, height: 4) { }
main "take"
details(["videoPlayer", "take", "motion", "refresh", "cameraDetails"])
//for photo
log.debug "Parsing '${description}'"
def map = [:]
def retResult = []
def descMap = parseDescriptionAsMap(description)
//Image
def imageKey = descMap["tempImageKey"] ? descMap["tempImageKey"] : descMap["key"]
if (imageKey) {
storeTemporaryImage(imageKey, getPictureName())
// handle commands
def take() {
def userpassascii = "${CameraUser}:${CameraPassword}"
def userpass = "Basic " + userpassascii.encodeAsBase64().toString()
def host = CameraIP
def hosthex = convertIPtoHex(host).toUpperCase() //thanks to @foxxyben for catching this
def porthex = convertPortToHex(CameraPort).toUpperCase()
device.deviceNetworkId = "$hosthex:$porthex"
log.debug "The device id configured is: $device.deviceNetworkId"
def path = CameraPath
log.debug "path is: $path"
log.debug "Requires Auth: $CameraAuth"
log.debug "Uses which method: $CameraPostGet"
def headers = [:]
headers.put("HOST", "$host:$CameraPort")
if (CameraAuth) {
headers.put("Authorization", userpass)
log.debug "The Header is $headers"
def method = "GET"
try {
if (CameraPostGet.toUpperCase() == "POST") {
method = "POST"
catch (Exception e) { // HACK to get around default values not setting in devices
settings.CameraPostGet = "GET"
log.debug e
log.debug "You must not of set the perference for the CameraPOSTGET option"
log.debug "The method is $method"
try {
def hubAction = new physicalgraph.device.HubAction(
method: method,
path: path,
headers: headers
hubAction.options = [outputMsgToS3:true]
log.debug hubAction
hubAction
log.debug "Hit Exception $e on $hubAction"
def parseDescriptionAsMap(description) {
description.split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
private getPictureName() {
def pictureUuid = java.util.UUID.randomUUID().toString().replaceAll('-', '')
log.debug pictureUuid
def picName = device.deviceNetworkId.replaceAll(':', '') + "_$pictureUuid" + ".jpg"
return picName
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
log.debug "IP address entered is $ipAddress and the converted hex code is $hex"
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( '%04x', port.toInteger() )
log.debug hexport
return hexport
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
log.debug("Convert hex to ip: $hex")
[convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
private getHostAddress() {
def parts = device.deviceNetworkId.split(":")
log.debug device.deviceNetworkId
def ip = convertHexToIP(parts[0])
def port = convertHexToInt(parts[1])
return ip + ":" + port
//for video
private getVideoURL() {
def videoURL = ""
if (CameraAuth) {
videoURL = "rtsp://${CameraUser}:${CameraPassword}@${CameraIP}:${CameraRtspPort}${CameraPathVideo}"
} else {
videoURL = "rtsp://${CameraIP}:${CameraRtspPort}${CameraPathVideo}"
return videoURL
mappings {
path("/getInHomeURL") {
action:
[GET: "getInHomeURL"]
def installed() {
configure()
def updated() {
configure()
/*def parse(String description) {
// handle commands
def configure() {
log.debug "Executing 'configure'"
sendEvent(name:"switch", value: "on")
def start() {
log.trace "start()"
def videoURL = getVideoURL()
log.debug videoURL
def dataLiveVideo = [
OutHomeURL : videoURL,
InHomeURL : videoURL,
ThumbnailURL: "http://cdn.device-icons.smartthings.com/camera/dlink-indoor@2x.png",
cookie : [key: "key", value: "value"]
def event = [
value : groovy.json.JsonOutput.toJson(dataLiveVideo).toString(),
data : groovy.json.JsonOutput.toJson(dataLiveVideo),
descriptionText: "Starting the livestream",
eventType : "VIDEO",
displayed : false,
isStateChange : true
sendEvent(event)
def getInHomeURL() {
[InHomeURL: getVideoURL()]
// for motion
def motion() {
log.debug( "motion() state" );
def strUrl = "http://${CameraUser}:${CameraPassword}@${CameraIP}/IO/outputs/1/status{}";
log.debug( "strUrl = ${strUrl}" );
httpPost( strUrl ){
def motionDisable = new XmlSlurper().parseText('''
</IOPortStatus>
def motionEnable = new XmlSlurper().parseText('''
<ioState>active</ioState>
</IOPortStatus>
