Quirky Refuel and SmartThings
Does anyone know if this will work with the V2 of the hub?
You can get it to work, but it requires editing some code and it’s fairly technical:
Unfortunately, you’re going to have to read that entire thread to get the jist because at one point it worked with one set of code and then somethings changed, and the code now has to be edited in order to work.
So, I think it will, but the set up is much more complex than most devices right now.
