Quickstart Guide needs updating?
I followed exactly the directions at
http://docs.smartthings.com/en/latest/device-type-developers-guide/quick-start.html
but when I get to the step “Test your Device Handler with Virtual Device” my virtual switch is already on.
Tapping on it just goes to “TURNINGOFF” and stays there forever.
It appears a lot of the screenshots on the page are out of date, too, so maybe something has changed that it doesn’t work anymore.
So, am I doing something wrong? If so, what?
Or did something change? And, if so, how do I compensate so I can get the quickstart to work in the current ecosystem?
Honestly, it is best to Never trust the Simulator!.
Publish your SmartApp using the “for me” option and then test with a real Switch or an actual instance of a Virtual Switch (not the simulator based Virtual Switch).
Are you referring to the note in the guide: “While the Simulator is useful and necessary for testing how the Device Handler handles incoming messages, we recommended that you test on the mobile app with Virtual Devices wherever possible.”
I think this is what I tried to do, and what the steps tell me to do? I didn’t use the Simulator. It is in testing it on the mobile app that I have the problem.
(At this point, I’m just trying to get started. It’s really hard to learn things, without at least something running and working to start with that I can play around with.)
You’re definitely following the right path, @marvin; it will take a little patience, but I’m glad you’re starting simple and incremental.
It wouldn’t hurt to paste the entire code you are using here (surround by three back-quotes ``` on a line by itself at start and end). Someone might see the obvious problem, or can paste the code into their own environment to debug.
But also walk through other simple examples like what’s in the SmartThings Public Git Hub repository:
I literally followed exactly the steps outlined at
The code is exactly the stuff that comes from the Dimmer Switch template, with the name, namespace, and author changed. (Just for completeness, though, it is pasted below.)
When you follow the step in the guide, does it work for you?
If so, then I must be doing something wrong, and I’ll try to figure out what it is.
If not, then something is wrong in the guide.
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "My Dimmer Switch", namespace: "marvinlast", author: "Marvin Last", ocfDeviceType: "oic.d.light") {
		capability "Switch Level"
		capability "Actuator"
		capability "Indicator"
		capability "Switch"
		capability "Polling"
		capability "Refresh"
		capability "Sensor"
		capability "Health Check"
		capability "Light"
		fingerprint mfr:"0063", prod:"4457", deviceJoinName: "GE In-Wall Smart Dimmer"
		fingerprint mfr:"0063", prod:"4944", deviceJoinName: "GE In-Wall Smart Dimmer"
		fingerprint mfr:"0063", prod:"5044", deviceJoinName: "GE Plug-In Smart Dimmer"
		fingerprint mfr:"0063", prod:"4944", model:"3034", deviceJoinName: "GE In-Wall Smart Fan Control"
	simulator {
		status "on":  "command: 2003, payload: FF"
		status "off": "command: 2003, payload: 00"
		status "09%": "command: 2003, payload: 09"
		status "10%": "command: 2003, payload: 0A"
		status "33%": "command: 2003, payload: 21"
		status "66%": "command: 2003, payload: 42"
		status "99%": "command: 2003, payload: 63"
		// reply messages
		reply "2001FF,delay 5000,2602": "command: 2603, payload: FF"
		reply "200100,delay 5000,2602": "command: 2603, payload: 00"
		reply "200119,delay 5000,2602": "command: 2603, payload: 19"
		reply "200132,delay 5000,2602": "command: 2603, payload: 32"
		reply "20014B,delay 5000,2602": "command: 2603, payload: 4B"
		reply "200163,delay 5000,2602": "command: 2603, payload: 63"
	preferences {
		input "ledIndicator", "enum", title: "LED Indicator", description: "Turn LED indicator... ", required: false, options:["on": "When On", "off": "When Off", "never": "Never"], defaultValue: "off"
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
				attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
				attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
				attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
			tileAttribute ("device.level", key: "SLIDER_CONTROL") {
				attributeState "level", action:"switch level.setLevel"
		standardTile("indicator", "device.indicatorStatus", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
			state "when off", action:"indicator.indicatorWhenOn", icon:"st.indicators.lit-when-off"
			state "when on", action:"indicator.indicatorNever", icon:"st.indicators.lit-when-on"
			state "never", action:"indicator.indicatorWhenOff", icon:"st.indicators.never-lit"
		standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
			state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
		valueTile("level", "device.level", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "level", label:'${currentValue} %', unit:"%", backgroundColor:"#ffffff"
		main(["switch"])
		details(["switch", "level", "refresh"])
def installed() {
	// Device-Watch simply pings if no device events received for 32min(checkInterval)
	sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
	response(refresh())
def updated(){
  switch (ledIndicator) {
        case "on":
            indicatorWhenOn()
            break
        case "off":
            indicatorWhenOff()
            break
        case "never":
            indicatorNever()
            break
        default:
            indicatorWhenOn()
            break
def getCommandClassVersions() {
		0x20: 1,  // Basic
		0x26: 1,  // SwitchMultilevel
		0x56: 1,  // Crc16Encap
		0x70: 1,  // Configuration
	def result = null
	if (description != "updated") {
		log.debug "parse() >> zwave.parse($description)"
		def cmd = zwave.parse(description, commandClassVersions)
		if (cmd) {
			result = zwaveEvent(cmd)
	if (result?.name == 'hail' && hubFirmwareLessThan("000.011.00602")) {
		result = [result, response(zwave.basicV1.basicGet())]
		log.debug "Was hailed: requesting state update"
	} else {
		log.debug "Parse returned ${result?.descriptionText}"
	return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
	dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
	dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelSet cmd) {
	dimmerEvents(cmd)
private dimmerEvents(physicalgraph.zwave.Command cmd) {
	def value = (cmd.value ? "on" : "off")
	def result = [createEvent(name: "switch", value: value)]
	if (cmd.value && cmd.value <= 100) {
		result << createEvent(name: "level", value: cmd.value, unit: "%")
	return result
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
	log.debug "ConfigurationReport $cmd"
	def value = "when off"
	if (cmd.configurationValue[0] == 1) {value = "when on"}
	if (cmd.configurationValue[0] == 2) {value = "never"}
	createEvent([name: "indicatorStatus", value: value])
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
	createEvent([name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false])
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	log.debug "manufacturerId:   ${cmd.manufacturerId}"
	log.debug "manufacturerName: ${cmd.manufacturerName}"
	log.debug "productId:        ${cmd.productId}"
	log.debug "productTypeId:    ${cmd.productTypeId}"
	def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
	updateDataValue("MSR", msr)
	updateDataValue("manufacturer", cmd.manufacturerName)
	createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
	[createEvent(name:"switch", value:"on"), response(zwave.switchMultilevelV1.switchMultilevelGet().format())]
def zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap cmd) {
	def versions = commandClassVersions
	def version = versions[cmd.commandClass as Integer]
	def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
	def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
	if (encapsulatedCommand) {
		zwaveEvent(encapsulatedCommand)
	// Handles all Z-Wave commands we aren't interested in
def on() {
	delayBetween([
			zwave.basicV1.basicSet(value: 0xFF).format(),
	],5000)
def off() {
	delayBetween([
			zwave.basicV1.basicSet(value: 0x00).format(),
	],5000)
def setLevel(value) {
	log.debug "setLevel >> value: $value"
	def valueaux = value as Integer
	def level = Math.max(Math.min(valueaux, 99), 0)
	if (level > 0) {
		sendEvent(name: "switch", value: "on")
	} else {
		sendEvent(name: "switch", value: "off")
	sendEvent(name: "level", value: level, unit: "%")
	delayBetween ([zwave.basicV1.basicSet(value: level).format(), zwave.switchMultilevelV1.switchMultilevelGet().format()], 5000)
def setLevel(value, duration) {
	log.debug "setLevel >> value: $value, duration: $duration"
	def dimmingDuration = duration < 128 ? duration : 128 + Math.round(duration / 60)
	def getStatusDelay = duration < 128 ? (duration*1000)+2000 : (Math.round(duration / 60)*60*1000)+2000
	delayBetween ([zwave.switchMultilevelV2.switchMultilevelSet(value: level, dimmingDuration: dimmingDuration).format(),
				   zwave.switchMultilevelV1.switchMultilevelGet().format()], getStatusDelay)
def poll() {
 * PING is used by Device-Watch in attempt to reach the Device
def ping() {
	refresh()
def refresh() {
	log.debug "refresh() is called"
	def commands = []
	commands << zwave.switchMultilevelV1.switchMultilevelGet().format()
	if (getDataValue("MSR") == null) {
		commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
	delayBetween(commands,100)
void indicatorWhenOn() {
	sendEvent(name: "indicatorStatus", value: "when on", displayed: false)
	sendHubCommand(new physicalgraph.device.HubAction(zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()))
void indicatorWhenOff() {
	sendEvent(name: "indicatorStatus", value: "when off", displayed: false)
	sendHubCommand(new physicalgraph.device.HubAction(zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 3, size: 1).format()))
void indicatorNever() {
	sendEvent(name: "indicatorStatus", value: "never", displayed: false)
	sendHubCommand(new physicalgraph.device.HubAction(zwave.configurationV1.configurationSet(configurationValue: [2], parameterNumber: 3, size: 1).format()))
def invertSwitch(invert=true) {
	if (invert) {
		zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
	else {
		zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 4, size: 1).format()
The DTH code you pasted will very likely never work with a Virtual / Simulated Switch, and that’s something the Docs don’t make clear.
The parse() method has to receive the exact correct messages. The simulator{} section describes these for use in the IDE Simulator (but these only work in the Simulator! They do not work with a “Virtual / Simulated Device”).
And the Simulator is unreliable.
So… Overall, the example is a poor one and relatively obsolete, unless you get lucky and understand the Simulator and the Simulator works reliably during your testing.
My recommendation:
  • Test using much simpler DTH code for an actual Simulated/Virtual Switch.
  • or Test using an actual physical Switch (e.g., a SmartThings ZigBee Dimmer Outlet) but be sure to use the correct source code for that model of Switch as the DTH code that you are studying and experimenting with.
Are you trying to build something specific?
Okay, I found the “Simulated X” templates, and am playing around with those, with much more success. Thanks!
Hi,
   Recently, I also encountered the similar problem, which you mentioned. How do you solve this finally?
Instead of using Dimmer Switch code with a virtual device, I used the Simulated ____ template.
I was trying to create a virtual button (that never has any physical button anywhere). If I remember right, the Simulated ____ templates seemed to work fine for that, and much easier than trying to use a real device template without a physical device.
If you have an actual physical device that you want to simulate, then this solution is not for you. But if you also want to create a virtual button (with no physical device), then take a look at the Simulated ____ templates.
OK, I will have a try. Thanks a lot.
