I just got my V2 hub and I’m hooked. I have installed a few items and more are coming.
I have a door sensor, light switch, motion sensor and a siren. I have a few questions about connecting some actions. It’s probably obvious but sometimes I get stuck on obvious items.
I know that I can attach options to the SmartHome Monitor and to the Routines but I want
motion detector to arm the system when we go to the bedroom and it’s after 10pm
arm system after midnight if 1 did not trigger
arm system was door sensor but can I add motion after 1am?
a. Use the door sensor in the security section of your Smart Home Monitor under "Armed Stay"
b. Create a mode called "Night"
c. Create a routine called “Good Night” that will be triggered by the motion sensor between 10pm and 1am.
When creating the routine, set the following:
i. Set Smart Monitor to = Arm(Stay)
ii. Change the mode to = Night
iii. Automatically perform “Good Night” when… = Things Start Happening (here select your motion sensor and Start/End times)
2. arm system after midnight if 1 did not trigger
Create a routine called “Night Check” that will run at 1am, if the home is not in “Night” mode.
When creating this routine, set the following:
iii. Automatically perform “Night Check” when… = At specific time …(1am)
3. arm system was door sensor but can I add motion after 1am?
Create a “custom” monitoring rule in your Smart Home Monitoring
i. “What kind of device” = motion sensor
ii. Select your device
iii. Under “More Options,” select “Only when mode is…” = “Night”
