As mentioned above, you can definitely do it using the LIFX IFTTT channel.
If you haven’t used the free IFTTT service before, the following is a good introduction:
So it’s not out of the box functionality, but it’s pretty straightforward:
- create a virtual switch in SmartThings
set up an IFTTT recipe so that turning on that switch activates the LIFX scene
have your button controller device turn on the virtual switch.
The amount of IFTTT lag varies from house to house, so you may just have to test it to see if it fits your use case.
Obviously not as good as a direct integration, but workable for many purposes.
p.s. This forum uses American date conventions. So Mar 13 is the 13th day of March this year, 4 months ago, not 3 years.
