Hi,
I have installed a Qubino Flush Dimmer (ZMNHDD1) behind a wall push-button.
I can control the dimmer with the SmartThings app. Switching on and off and setting a dimmer-value works fine with the app.
However, when I try to dim the light using the push-button (by holding the button for a couple of seconds), the dimmer does not respond. I can swith the light on and off with the push-button.
I have connected the output-wire from the push-button to Input1 of the Qubino. I have checked if all the parameters are set correctly.
I use the erocm123 device handlers: ‘Qubino Flush Dimmer’ and ‘Contact Sensor Child Device.’
What do I need to do to be able to dim the light using the push-button?
Thanks for your help!
Henk
