It depends on what generation of ST key-fob presence detector you have. The original sensors use the IDE’s setting. The newer ones being sold today use the setting within the mobile app. ( IIRC )
If you got to the “My Home” screen to list all your devices, then click on a presence sensor, then click on the settings cog at the top right, the bottom option above the remove button allows you to specify a timeout for that device.
I’ve only just seen the setting in the IDE so I haven’t had a chance to experiment tweaking both the values yet but wondered if anyone in the forums had already knew.
Oh that’s good to know. Bit of a shame as the IDE setting allows more flexibility. I’m having a bit of a hard time getting my presence sensor to act reliably (even bought a power outlet to repeat the signal right next to where I leave my keys) and having a timeout greater than 5 minutes could’ve helped.
Must be because I’ve been too paranoid to update the app recently, but on my iPad that option does not exist. The available options are
Give your device a name
Set device image
Remove
The option will only exist if you’re using a newish model of the ST Zigbee Keyfob Presence Detector. The older model (both in the oval and rectangular packaging) use a different Device Handler which does not expose that setting.
