Was able to snag some PlantLink hubs and sensors for $17.06 each. My local home depot had 7 of these sitting in clearance so you probably need to go in your local store and check.
are those Zwave? I could find some interesting uses for those soil sensors
these are actually zigbee
close enough thanks!!!
Nice find. I could use a cpl. Heading to my HD tomorrow. It’s 30 mi away but I usually find a cpl good toys.
Hey I’ll buy you one if you want to ship me a couple
[quote=“dshokouhi, post:564, topic:34950”]
[/quote]These sensors only work with their hub, correct?
they work directly with ST. They added them recently
u can connect it directly to ST hub
I plan on checking my local HD tomorrow, but only if you found these in an area other than the connected devices are, because I am always in that area and they aren’t there. Can you let me know if it was in a different section?
Also Interesting I wonder if they were returned, because the website says:
Also I’m not sure if it’s a deal since you posted these at 17.06, but if you see my banner they are $35 at amazon.
$35 should be the add-on plant links.
EDIT: Wow. That normally would be the add-on, but I do see someone is selling the full unit for that price, only a few left in stock though.
so 50% off is not a good deal lol? I found these in the main clearance dump but they may be in other areas, check the garden clearance section. I noticed today that each aisle has its own clearance section so it may be worthwhile to walk around
I didn’t CamelCamelCamel it at the time, and beings that the posted picture was half the price I posted, I thought I would throw a disclaimer out there…
Just did the survey and ordered one too. Thanks for the info. I was only able to use the code once but I will still take a smart bulb for $7.99!
Still working for me, too. Awesome find on this. I was just showing my boss the Sengled bulbs (specifically the Snap and Pulse Solo) yesterday. Perfect timing. I can find a use for another bulb somewhere I’m sure!
Thanks! Worked for me too. I am always willing to try a new bulb, especially for 8 bucks.
OK guy’s and Gal’s I am looking for the GE Z-Wave or Zigby paddle single pole switch not dimmer, Lowes seems to not be carrying them any ideas as I want them to have the blue LED as my others. Also the best deal available.
Do you all have the link for the light bulb for 7.99 with discount code? I not seeing it?
Here you go…
20 char. jhxfjghksdjfhgksjdfgkjhgdf
Were you asking for a direct link to the bulb?
https://www.sengled.com/product/element-touch
Hard to tell by the name what it is.
My expired survey just worked, I’ve received a notice of an order.
@TEWphotography Thanks for the heads-up on this one (sengled).
I got confirmation too.
I didn’t really need another smart bulb, but I did need a smart bulb of a different brand. Anything I don’t have yet, I want one. So, when something like this comes along, bingo!
