Post Requests for Zigbee Edge Drivers Here (community-created)
Hi,
Could you please add this Zigbee 3.0 Heiman smoke sensor to your driver?
Product model: HS1SA-E
Model: TS0205
Manufacturer code: _TYZB01_hr7c7xlf
Hi @mikc2
Added to this driver version
Install this driver version in your hub
uninstall and reinstall device to new profile assigned and device configured
Do not perform a driver change
 Name         Zigbee Smoke/CO Detector Mc
 Version      2024-10-24T21:08:41.933834138
- id: "_TYZB01_hr7c7xlf/TS0205"
    deviceLabel: HS1SA-E Smoke Detector
    manufacturer: _TYZB01_hr7c7xlf
    model: TS0205
    deviceProfileName: smoke-battery
Thanks a lot!
Smoke sensor detected that driver automatically and uses it, even without any manual updates.
Unfortunately when I press the test button on the smoke sensor it does not show notification in the smartthings app.
I did remove the device and added it again, but that didn’t help. Any idea what may be causing it?
The smoke sensor seems to be working fine, cause when I added it to the Smart Life (Tuya) app, it does show the notification alert there when pressing the test button - but in the smartthings app it does not.
Install this driver version in your hub and reinstall device with it
 Version      2024-10-26T11:12:33.006691663
Hi everyone!
New guy here, first post. Im looking for help with a driver for a soil sensor I got off AliExpress
(https://www.aliexpress.com/item/1005007330089764.html?spm=a2g0o.order_list.order_list_main.17.10271802dMTJee)
Model : TS0601
Manufacturer Code: _TZE284_aao3yzhs
Is there any other info I need to provide?
Have you seen this driver
Yeah, it still doesn’t show any info
Have you paired it with the β€œZigBee Thing Mc” driver to see if it has EF00 clusters. If it has the EF00 clusters what I recommend is probably your only option.
I tried to go with the guide but I dont really understand how to use it. The device was added automatically but Im still getting gibberish instead of actual data
i just bought the same soil sensor, i’m still trying to make it work with the EF00 generic driver without success, to see the debug info, nowaday ZigBee Thing Mc is outputting debug info in the history tab.
As i can see EF00 generic driver is not in active development anymore, and our device fingerprint is not registered on the driver.
Have you posted in this topic [ST Edge] Personal Tuya Devices - Generic EF00 Device ? Wesley was responding to posts in Sep.
i’ve just saw that, thanks, the Data point for the same device are even there. Awesome
Use the EF00 generic driver, under settings change the Profile to β€œTemperature & Humidity”.
The device page will reload, go to Settings, and this time change Profile to β€œ+Battery”, it will reload again.
Go to settings again, for DP for Relative Humidity Measurement put 3, for DP for Temperature Measurement put 5, and for DP for Battery put 15.
The Temperature will now appear, the humidity and battery take a little more time to report.
Enjoy :slight_smile:
It works great! Thank you so much!
The battery may seem a bit unreliable but I’ll give it more time to see how it goes
Can you explain how you got to the DP values? I can try to tinker with them a bit to get more accurate results
good day everyone,
i have bought a 2 button switch from Tuya (Linkoze Branded), Model LKWSZ211.
I belive many of you are using this but different brand.
Could you please add: β€œ_TZ3000_kt7obmnn” into the drivers? Thank you!
There are numerous community created ZigBee button drivers that might work. You need to find the and give them a try. The following are some possible places to look
I have one of these (I think), but I can’t even figure out how to get the ST hub to see it. Can anyone give me a hint on how to get it added? I already added the above driver ^^ :slight_smile:
Hi @Bryan_Gintz
Install zigbee thing Mc driver from my channel on your hub.
try to start the device and post the manufacturer and model data shown
Where do I find the manufacturer and model data, or rather, where will it show? Sorry for the newbie questions.
When device is paired with zigbee thing Mc driver
