Post Requests for Zigbee Edge Drivers Here (community-created)
Where do I find the manufacturer and model data, or rather, where will it show? Sorry for the newbie questions.
When device is paired with zigbee thing Mc driver
Ok, great, I am still trying to get it paired, lol, tried taking battery out and back in, tried pressing reset button 5 times fast and also holding for 5 seconds…will keep trying!!
Hi, new to zigbee - so ended up with cheap swithch fro Aliexpress not working… Found this great thread, and have added channels @Mariano_Colmenarejo, @zambobmaz and @erickv - really great work.
Problem:
4 button switch
Model TS0044
Type ZIGBEE
Manufacturer Code _TZ3000_mh9px7cq
Found in @erickv β€˜button-battery-v1.4.3’ - so added driver, removed switch and re-paired. Detected OK, but onlys shows 2 button - and writes β€˜has not updated all status information’ when entering setup in app.
How to solve??
BR Frank
UPS… Found there was a version 1.4.4 - reinstalled - and works :slight_smile:
Again: THX for supporting this
You may be interested in this: Driver for Aqara FP1E Presence Sensor (Direct Hub Connection via Zigbee)
i got an tuya smoke detecor
Manufacturer_TZE204_kgaxpvxr
ModelTS0601
Endpoint0x01
Device ID0x0051
Network ID0xCF46
Profile ID0x0104
Server Clusters
Groups0x00040x01
Scenes0x00050x01
Basic0x00000x01
?0xEF000x01
Client Clusters
Time0x000A0x01
OTAUpgrade0x00190x01
with driver i can use for this?
Your device has EF00 clusters so you need to used the following driver.
Hi @Mariano_Colmenarejo can you please add this water leak sensor to your driver?
Hi,
Added to this driver version
Install this driver version in your hub
uninstall and reinstall device to device configured
Do not perform a driver change
 Name         Zigbee Moisture Sensor Mc
 Version      2024-12-21T13:12:20.984689657
- id: "SONOFF/SNZB-05P"
    deviceLabel: SNZB-05 Water Sensor
    manufacturer: SONOFF
    model: SNZB-05P
    deviceProfileName: moisture-battery
Hi Members,
I have Hue Smart Button. I do not have Hue hub. I would like to add directly to ST Hub. When I added this device, it comes as β€˜Zigbee Thing’.
Can some one please add the below details to proper driver?
  • id: Philips Hue Smart Button
    deviceLabel: Philips Hue Smart Button
    manufacturer code: Signify Netherlands B.V.
    model: ROM003
    deviceProfileName: one-button-battery
@Praveen_K Try the Hue Dimmer Switch driver. You can find it at
Thank for the response.
I tired , but it is not showing up in the drivers list. I think the model is brand new and it needs to be added to a handler that contains zigbee smart buttons.
Please advise.
Post the information that you posted above in @iquix 's thread and ask if he can add your fingerprints to his driver.
Ok. Thank you.
Hi Mariano,
Can you please help adding the below for Zigbee Button? Appreciate your help.
    model: ROM003
Hi, @Praveen_K
Sorry, I have no idea how this device works.
It is a smart button with Single/Double/Long Press. It is from Philipps Hue.
Can you help here? Anyone?
Install the Zigbee Thing Edge driver from this channel, change your device to this driver and post a screenshot of the device card in this topic.
