looking for a driver for my zemismart zigbee curtain motor
This channel has @iquix driver fir this device
https://bestow-regional.api.smartthings.com/invite/qWjB0pNyY62y
Yes, this is the correct driver
That worked Thank you!
How are you?
Is it possible to create a driver based on a Hubitat DHT? This device has an ultrasonic sensor that measures the water level in a tank. It works with Hubitat. Iβll leave the link to the DHT and the review I did on it below in case you want to check it out.
Hi @niquini, Iβm fine and I hope youβre fine too.
Sorry I canβt do this, itβs too complicated and would require a lot of work and debugging.
It seems like it was recently, but itβs been 3 years since we started with edge and I havenβt used groovy code since then and following the DTH of a master like KKossev is not easy for me at the moment.
The data points of the EF00 cluster that the device uses are very well explained in the DTH, as I was saying, Kkossev is fantastic at making DTHβs.
Maybe @w35l3y can add it in his personal tuya EF00 cluster driver, he would have part of the work done in it.
Hello, I have a Heiman gas detector that is using Marianoβs Zigbee Smoke/CO Detector Mc driver. Itβs some years old now and occasionally bleeps which I guess is its way of telling me to replace it. I purchased a direct replacement from China but Smartthings only recognises it as a Thing. I cannot change the driver as there is no alternative. Can the driver be tweaked please?
Not sure what information is needed but here are the details from ST Advanced:
Please help! TIA
Hi,
Added to this driver version
Install this driver version in your hub
uninstall and reinstall device to new profile assigned and device configured
Do not perform a driver change
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Smoke/CO Detector Mc
Version 2024-10-09T17:53:12.398086947
- id: "TS0204/_TYZB01_0w3d5uw3"
deviceLabel: TS0204 Gas Sensor
manufacturer: _TYZB01_0w3d5uw3
model: TS0204
deviceProfileName: gas-detector
+1 request For a MHCozy edge driver 4 Channel
model : TS0004
Manufacturer code: _T23000_hdlplfbk
Finally trying to install this and thought for a second it might be easy when it connected itself, but it only sees one channe
4 Channel 12V ZigBee Relay Switch with Clean Contact, Adjustable Self-Lock and Momentary Interlock Working Mode,Automate Garage Gate Door Blind(Zigbee Hub Needed)
What driver are you using? Have you tried the βZigBee Multi Switch and Child Mcβ driver.
Name Zigbee Multi Switch and Child Mc
Version 2024-10-19T08:58:54.206614663
- id: "TS0004/_TZ3000_hdlplfbk"
deviceLabel: MHCozy 12V Four Switches
manufacturer: _TZ3000_hdlplfbk
model: TS0004
deviceProfileName: four-switch
Wow - thatβs super fast! Iβm amazed. I did find it with the update.
But still a problem (becuase thatβs how these things go)
As you said, The 'change driver" doesnβt work.
Basic follow up - Iβll keep looking.
Canβt figure out how to add it and select that driver in the process. It keeps selecting βZigbee switchβ.
Hi,
New version will be updated automatically in 12 h max
you can delete the driver from your hub and install last driver from the channel
Hi @Mariano_Colmenarejo can you please add this door sensor to your driver?
Hi,
Name Zigbee Contact Mc
Version 2024-10-22T09:14:27.235473946
- id: "_TZ3000_jiocgoks/Contact Sensor"
deviceLabel: TS0203 Contact Sensor
manufacturer: _TZ3000_jiocgoks
model: TS0203
deviceProfileName: contact-battery-profile
Thank you!
Hi @Mariano_Colmenarejo can you please add this Tuya Vibration/Tilt angle to your driver?
Model TS0601
Manufacturer Code _TZE200_iba1ckek
Sorry, I think it uses tuya cluster EF00
