I hope this is the right place to ask. I’m looking for a ST Edge Driver for a Zigbee temp/humid sensor with display from aliexpress. It’s working with the Tuya App without problems of course. I already installed the Personal Tuya Devices Driver and Zigbee Thing Mc, but the problem is this:
I can find the device with “scan nearby” and add it
I get some generic information, e.g. that it is using the ef00 cluster
but that is the only time the sensor sends data, the first and last time
when it’s "paired’, it get’s stuck and no more updates are send and even the data on the device’s display gets no update and stays the same
internal name is TZE204_upagmta9 (manufacturer) and TS0601 (model)
some deep search led me to HA integrations and that the device seems to be “waiting” for some command and that’s why it stays in a freeze-state or endless loop.
I’m looking for a driver for this. It’s a 3 gang light switch which I’ve just fitted. I did add all of the Mariano drivers to the hub and as you can see it could use the thing or thing mc, however neither of them give me switches and the thing mc gives me a garbled readout in the smart things app.
Install this driver version in your hub
uninstall and reinstall device to new profile assigned and device configured
Do not perform a driver change
Name Zigbee Multi Switch and Child Mc
Version 2024-09-25T21:14:38.063951673
- id: "TS0013/_TZ3000_5e5ptb24"
deviceLabel: Wifi Smart Home Three Switch
manufacturer: _TZ3000_5e5ptb24
model: TS0013
deviceProfileName: three-switch
sorry for my ignorance but i dont understand how to pair chosing a driver version ? pair using web interface or Android app ? Android Smarthing app being latest 1.8.18.21 … thanks
There is only one version of the driver installed on the hub, usually the latest one that exists on the channel from which it was downloaded.
When a new version of the driver is released (date and time of compilation) it will be automatically installed on the hub within a maximum of 12 hours.
You can see the version of the driver installed on the hub, driver menu. Find the driver and click on it and you will see this information.
You can also see it in the driver menu of a device that is paired with the driver.
thanks that quick answer ! : your answer is about seeing/verify current drivers : i dont have the “Zigbee Multi Switch and Child Mc” nore the Edge Driver Beta … my hub is into auto/update mode and i dont know how to add any driver ? i usually find my way in computer/cell but not this time ouiinnn my hub is a V3
all custom edge drivers are added in the same way.
you get the link to the author’s “channel”, typically from a thread in this forum, but maybe from a blog post or the device manufacturer or github.
You follow that link and subscribe to the channel.
Then select the specific edge driver you want to have downloaded to The specific hub you want to download it to. (some people have more than one hub with different edge drivers on each.)
The edge driver will then be automatically downloaded to that hub. It usually happens right away, but some people have reported waits of a couple of hours the first time.
And that’s that. After that, the edge driver will show up in the information for that hub in your account. and as long as you are subscribed to it, it will be automatically updated when the author makes updates.
It sounds like you might benefit from reading the community FAQ on edge drivers. The official documentation is pretty sparse.
thanks ! i’v finally found some links to Mariano Mc drivers and suceed with my Ikea Badring sensor
i feel like i’m back in 1999 dealing with Windows95-98 drivers
this is the direct link for Mariano Mc drivers :
Now i’m trying to get my Aeotec Energy Gen5 meter to work using Aeotec channel, still not working
this is the direct link to Aeotec Drivers channel :
Hi @Mariano_Colmenarejo I am trying to install several Tuya Zigbee Moisture sensors. I have added both the Zigbee Moisture Sensor Mc and Zigbee Thing MC drivers, however only the Zigbee Thing MC is appearing as an option when selecting the driver, I cannot select the Moisture Sensor Driver. Is it possible to add this device to the Moisture sensor driver?
