That’s a problem with the app, sometimes it goes fast, other times it goes very very slow, other times it shows a status in the mosaic and another in the details view and sometimes need to close it and reopen it for app to work properly. Hopefully they’ll fix it someday
I say that it is the fault of the smartthings servers or app, because I can see with the CLI the logs that reach the driver from the app and from the device and the driver as soon as it receives the command sends it to the device and the device responds in tenths of a second and the driver emits the new status to the platform immediately and it takes several seconds later to be seen in the App.
In this example was received a on command at 09:53:21.611199876Z and the new On event to a default response was emitted at 09:53:21.749589001Z, in 0.13 sec.
A second on report attribute message was received and was emitted a new On command at 09:53:21.883414459Z, total 0.27 sec to emit two On events.
In app the On response was show more of 4 sec after
2024-09-26T09:53:21.611199876Z INFO Zigbee Switch Mc hub handled command: 23b34f80-16bf-47c1-938a-80497f29bb0e:main:switch:on
2024-09-26T09:53:21.612313167Z INFO Zigbee Switch Mc hub sending: Zigbee message (23b34f80-16bf-47c1-938a-80497f29bb0e): <src_addr: 0x00, src_endpoint: 0x1, dest_addr: 0x158d, dest_endpoint: 0xb, profile: 0x104, cluster: 0x06, data: [01, 00, 01]>
2024-09-26T09:53:21.724922209Z TRACE Zigbee Switch Mc Received event with handler zigbee
2024-09-26T09:53:21.725825667Z INFO Zigbee Switch Mc <ZigbeeDevice: 23b34f80-16bf-47c1-938a-80497f29bb0e [0x158D] (Lidl Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x158D, src_endpoint: 0x0B, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -61, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5D, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2024-09-26T09:53:21.748542626Z TRACE Zigbee Switch Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_Mc
2024-09-26T09:53:21.749589001Z INFO Zigbee Switch Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2024-09-26T09:53:21.751073834ZINFO Zigbee Switch Mc <ZigbeeDevice: 23b34f80-16bf-47c1-938a-80497f29bb0e [0x158D] (Lidl Plug)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2024-09-26T09:53:21.784288667Z DEBUG Zigbee Switch Mc Lidl Plug device thread event handled
2024-09-26T09:53:21.819439584Z TRACE Zigbee Switch Mc Received event with handler zigbee
2024-09-26T09:53:21.826222542Z INFO Zigbee Switch Mc <ZigbeeDevice: 23b34f80-16bf-47c1-938a-80497f29bb0e [0x158D] (Lidl Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x158D, src_endpoint: 0x0B, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -62, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x66, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true
2024-09-26T09:53:21.850691376Z TRACE Zigbee Switch Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_Mc
2024-09-26T09:53:21.851588459Z INFO Zigbee Switch Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2024-09-26T09:53:21.852935126Z INFO Zigbee Switch Mc <ZigbeeDevice: 23b34f80-16bf-47c1-938a-80497f29bb0e [0x158D] (Lidl Plug)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“2024/09/26 Time: 11:53, LQI: 200 … rssi: -62”},“visibility”:{“displayed”:false}}
2024-09-26T09:53:21.869761084Z INFO Zigbee Switch Mc <ZigbeeDevice: 23b34f80-16bf-47c1-938a-80497f29bb0e [0x158D] (Lidl Plug)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2024-09-26T09:53:21.883414459Z INFO Zigbee Switch Mc <ZigbeeDevice: 23b34f80-16bf-47c1-938a-80497f29bb0e [0x158D] (Lidl Plug)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:1000}}
The periodic reports setting is to reduce the number of messages that the devices send periodically to report their current status to the hub and not show them offline.
By default in the lua libraries of the firmware, messages are configured every 300 sec for the onOff cluster. I have it set to 1200 sec in my devices and it works well. It sends 4 times less messages to each device, this should free up work for the hub and reduce message traffic on the zigbee network when user has a lot off devices
