Hi! Could you please add this ewelink water leak sensor?
Model
SNZB-03
Manufacturer Code
eWeLink
Model
SNZB-03
Manufacturer Code
eWeLink
Instructions are linked from the first post in this thread. Please read that carefully: it has the information that you need to post with your request here so that the developers can help you.
Try using the Zigbee Moisture Sensor Mc driver from Mariano Shared Beta Driver channel. I have a device very much like this that works with this driver.
The reference you gave is incorrect.
Channel link
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
I already installed the Zigbee Moisture Sensor Mc driver from Mariano but itβs only showing up as zigbee thing. I think they need to add the deviceβs fingerprint to the driver.
Then, to see if they can be added, install the Zigbee Thing Mc from this same channel, and post the screen this driver shows.
Then we can see if @Mariano_Colmenarejo could kindly add the fingerprints ![]()
Go to my.smartthings.com, advanced users.
search the device and post the model and manufacturer code
Hello, I recently acquired a Sonoff SWV-NH Zigbee Smart Water Valve. It was detected natively by Smartthings, but as a regular on//off switch.
@Mariano_Colmenarejo , can you add the following device to your Zigbee Valve MC driver ?
This device also has flow measurement , if this is possible on your end.
Thanks !
Hi @Super8
Added to this driver version.
Sorry, I doubt by the model SNZB-03 because it is known everywhere as a motion sensor.
You need to instal this driver version in your hub
uninstall devices and reinstall devices with this driver version to devices were configured
do not perform a driver change
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Moisture Sensor Mc
Version 2024-09-16T11:59:15.251703994
- id: "eWeLink/SNZB-03"
deviceLabel: SNZB-03 Water Sensor
manufacturer: eWeLink
model: SNZB-03
deviceProfileName: moisture-battery
Hi @ellie
Name Zigbee Valve Mc
Version 2024-09-16T12:06:32.316178269
- id: "SONOFF/SWV"
deviceLabel: SONOFF SWV Water Valve
manufacturer: SONOFF
model: SWV
deviceProfileName: water-valve
The device is now working.
Thank you for your help.
Hi @Mariano_Colmenarejo
Somehow the driver does not recognize the device. I deleted it and repaired, yet still unable to select Zigbee Valve MC
When originally paired, it was under device profile as βswitchβ then I changed it to be a βvalve-battery-powerSourceβ via the Edge Builder and applied the change locally, it now sees it as a valve. It works for me locally, but does not serve much the community, it would make much more sens to see it as a valve.
I wonder if there could be a mismatch between the device profile listed βwater-valveβ in the fingerprint versus the βvalve-battery-powerSourceβ Just a thought but itβ's worth giving it a try ![]()
Hi,
If your device is powered by battery and external power I can change it to that profile.
The profile is not the problem for it not pairing.
It pairs with the fingerprints: manufacturer and model.
Has the driver been updated to the latest version on your hub?
Hello again
yes, looks like the drivers never made itβs way thru my hub. I forced deleted and reinstalled, The Sonoff SWV-NH now works as valve. Thanks !
For future changes when you have a moment, you may want to add battery status and power sources capabilities, this would replicate what the stock driver enables for this type of device.
For now and Open/Close state works
Hello,
Modified to desired profile.
Install this driver version
uninstall and reinstall device to new profile assigned and device configured
Version 2024-09-16T17:46:35.236553107
- id: "SONOFF/SWV"
model: SWV
deviceProfileName: valve-battery-powerSource
Works like a charm Mariano !Again thanks for making another driver available to the community.
One trick I can share to the group is how to change the drivers without having to delete and repair the device, hence not losing the devices in automations.
Step 1) Go to the web app via this link https://my.smartthings.com/
Step 2) select the Hub in the left pane then select your hub
Step 3) Scroll to the Installed Drivers section, or use the link at the top
Step 4) Select the driver and click the trash - confirm deletion when prompted
Step 5) Go to the driver invitation channel - The drivers at this point should be unassigned to your hub - Simply click to Install
Step 6) Go back to the web app (refresh the page) and you should see the new driver version installed .
Hope this helps !! Enjoy
Yes, it can be make in App deleting de driver in Hub drivers menu too
I hope this is the right place to ask. Iβm looking for a ST Edge Driver for a Zigbee temp/humid sensor with display from aliexpress. Itβs working with the Tuya App without problems of course. I already installed the Personal Tuya Devices Driver and Zigbee Thing Mc, but the problem is this:
some deep search led me to HA integrations and that the device seems to be βwaitingβ for some command and thatβs why it stays in a freeze-state or endless loop.
more information here Tuya ZTH05 sensor Humidity & temperature Β· Issue #19137 Β· Koenkk/zigbee2mqtt Β· GitHub and [Device Support Request] TS0601 _TZE204_upagmta9 Tuya outdoor temperature and humidity sensor Β· Issue #2694 Β· zigpy/zha-device-handlers Β· GitHub
datapoints could be taken from here WIP feat: Tuya datapoints modernExtend by kirovilya Β· Pull Request #6733 Β· Koenkk/zigbee-herdsman-converters Β· GitHub
is it even possible to make such βcustomβ pairing steps with a st edge driver?
Got a Maxcio Door/Window Sensor that connects as a Zigbee Thing. Can you add this please?
| Manufacturer: _TZ3000_bdoswav6 Model: TS0203 FingerPrinted_EndPoint.Id: 0x01 App Version: Unknown ZCL Version: Unknown Network ID: 0x2EC3 Zigbee EUI: A4C138FC84DF0750 Device ID: 1a676021-a9a8-49f1-afc2-3e4ffa064c9b Server Cluster: Ep: 0x01={ 0001,0003,0500,0000 } Client Clusters: Ep: 0x01={ 0003,0004,0005,0006,0008,1000,0019, 000A } Signal Metrics: |
