Is my first time here…
I need drivers for my zigbbe “circuit breaker” (isn’t a real circuit breaker)
Thanks…
This code ?
| Manufacturer: _TZE204_fhvdgeuh Model: TS0601 FingerPrinted_EndPoint.Id: 0x01 App Version: 0x4A ZCL Version: 0x03 Network ID: 0x2865 Zigbee EUI: A4C1384202B82D8C Device ID: b0e16c29-ab0a-42b5-9a3b-895627de966b Server Cluster: Ep: 0x01={ 0004,0005,EF00,0000 } Client Clusters: Ep: 0xF2={ 0021 } Ep: 0x01={ 0019,000A } Signal Metrics: LQI: 148 .... RSSI: -63 dbm |
Hi,
This device user EF00 tuya cluster and does not work with my driver.
It could works with personal tuya EF00 driver
Unfortunately it didn’t work… if I put it in power meter it even reads but I can’t activate or deactivate the device.
But I appreciate the help…
Thanks !
Aqara FP1E
Manufacturer: aqara
Model: lumi.sensor_occupy.agl1
App Version: 0x1A
ZCL Version: 0x03
Network ID: 0x8BF2
Zigbee EUI: 54EF441000DB418F
Device ID: 1493e61f-3222-46f3-8d29-1deb2f57643d
Server Cluster:
Ep: 0x01={ 0000,0003,FCC0 }
Client Clusters:
Ep: 0x01={ 0003,0019 }
Signal Metrics:
LQI: 210 … RSSI: -57 dbm
Thank you
Update 7/9/24 Returned as FP1E is zigbee matter over bridge. I have ordered the Meross MS600 as an alternative which is matter over WiFi.
You can ask to @w35l3y if there is a switch profile with energy meter capability or if I can add it.
[quote=“Mariano_Colmenarejo, post:1575, topic:262081, full:true”]
Have you tested the thermostat?
I need to know if it works well to merge it with the Mc driver and delete the TEST driver
Soil anyone know if there’s any Edge drivers for adult toys love sense all that it’d be great to be able to add them into my smartthings plus it’d be better than getting a notification from a door bell lol
Hi @Mariano_Colmenarejo and community! I am new around and to ST so apologies for any stupid comments of mine here…
I have bought a couple of these Zemismart Tuya Zigbee switches and I cannot find a working driver. I was initially told it would work with your Zigbee Multi Switch and Child Mc driver, Mariano … but I can’t get it to work, maybe it’s me … ![]()
4gang 2 scene:
Manufacturer: _TZ3000_s678wazd
Model: TS0726
App Version: 0x46
ZCL Version: 0x03
Network ID: 0xBE77
Zigbee EUI: A49E69FFFE4EDA3C
Device ID: 38b6c1a7-6b02-433f-ac9f-2e93d56f4bbd
Server Cluster:
Ep: 0x06={ 0003,0004,0005,0006,E000,E001 }
Ep: 0x05={ 0003,0004,0005,0006,E000,E001 }
Ep: 0x03={ 0003,0004,0005,0006,E000,E001 }
Ep: 0x02={ 0003,0004,0005,0006,E000,E001 }
Ep: 0x01={ 0000,0003,0004,0005,0006,E000,E001 }
Ep: 0x04={ 0003,0004,0005,0006,E000,E001 }
Client Clusters:
Ep: 0xF2={ 0021 }
Signal Metrics: LQI: 180 … RSSI: -91 dbm
single switch:
Manufacturer: _TZ3000_y4che4dc
Model: TS0001
App Version: 0x50
ZCL Version: 0x03
Network ID: 0x8482
Zigbee EUI: 0CEFF6FFFEC10F3F
Device ID: 3d40e277-7c4d-4e95-ac2b-457475dc7cf6
Server Cluster:
Client Clusters:
Ep: <0x01={ 0019,000A }
Ep: 0xF2={ 0021 }
Signal Metrics: LQI: 110 … RSSI: -96 dbm
These are the only 2 versions I have installed so far.(wondering if I can get them to work, then proceed to 2 and 3 gang versions sitting in the box)
If you could kindly point me to the correct driver or add this to a working driver, I would gladly appreciate it!
Hi @Ricardo_D
Added to this driver version
Yupu need to instal this driver version in your hub
uninstall devices and reinstall devices with this driver version to devices were configured
Name Zigbee Switch Mc
Version 2024-08-23T22:03:11.115137245
- id: "_TZ3000_y4che4dc/TS0001"
deviceLabel: TS0001 Switch
manufacturer: _TZ3000_y4che4dc
model: TS0001
deviceProfileName: single-switch
Name Zigbee Multi Switch and Child Mc
Version 2024-08-23T22:03:55.017509755
- id: "TS0726/_TZ3000_s678wazd"
deviceLabel: TS0726 Switch
manufacturer: _TZ3000_s678wazd
model: TS0726
deviceProfileName: six-switch
Hey @Mariano_Colmenarejo ! Thanks for the prompt response and the quick fix ![]()
I cannot find the correct version numbers you mentioned above in your edge driver channel my hub is enrolled to …
- id: “_TZ3000_y4che4dc/TS0001”
model: TS0001
───────────────────────────────────────────────────- id: “TS0726/_TZ3000_s678wazd”
model: TS0726
I removed the drivers and reinstalled but it seems to have older versions (2024-08-01T15 for the Zigbee Multi and 2024-08-22T20 for the Zigbee Switch Mc … are there specific links for these new versions, is it just a matter of time for the edge channel to get updated or maybe I have the wrong channel link?
Again, apologies if it is a dumb question and thank you.
I purchased the Aqara FP1E presence sensor, but I do not have an Aqara hub, and thus am not able to use it. I would generally like to avoid purchasing yet another hub and would prefer to have local control by directly pairing it to my SmartThings hub.
How likely is it that an ‘official’ stock driver will be generated for the FP1E, especially given that the prior version, for the FP1, is now supported? Post elsewhere in forum: FP1in stock driver
And, given that a FP1 driver was enabled in ygerlovin’s driver would it be feasible to create a Community Edge driver for the FP1E, with that as the starting point?
Also, a search indicates that there is a groovy driver that is functioning for Hubitat: Hubitat Forum post for FP1 / FP1E driver. So, paring it to a non-Aqara hub appears feasible.
Is a driver for the FP1E likely to be created by SmartThings or a community developer, or should I relent and buy an Aqara (E1 or M2) hub?
Thanks.
I think you would need the Aqara M3 hub for the full Matter experience. I am probably going to send back the FP1E as it’s matter over bridge, so not really properly in the spirit of Matter and somewhat nonsensical imho. I have ordered the Meross MS600 instead.
The Meross Presence Sensor looks compelling, but for now I’m likely to retain the FP1E.
The Meross sensor is WiFi based; while the FP1E is zigbee based.
Part of why I want to avoid a new hub is to prevent the additon of more WiFi devices, as I would need to connect it via that method
Meanwhile I hope that some information on the availability of an edge driver for the FP1E emerges soon. If it does not I will consider other options.
You will not get full functionality without the Aqara Home App and an Aqara Hub as stated on their website. I have now returned my FP1E and await my Meross MS600.
I have a request.
A zwave driver exist for zemsmart curtain motors. Zemismart discontinued the zwave curtain motor so is now only selling the Zigbee curtain motor.
It would be nice if I could directly add the zigbee curtain motor to smartthing instead of going through Tuya MOES smart hub. I dont get to use the zigbee mesh network that I already have in my home when it uses MOES.
I’m not sure how to get the finger print if someone knows happy to provide it.
