From what I see in your screenshots, your device is a remote control with 4 buttons (multi-Button)
Ah..ok, I have reached out to Erickv, letβs see if he will respond. I am now able to pair it and trigger routines. I just get this βdevice has not upatedβ¦β message now.
Hi @Mariano_Colmenarejo
Can you add my fingerprint at your drive Zigbee multi switch and child devices?
Itβs a tree gang switch
Added to this driver version
Do not perform driver change from zigbee thing, pair device with this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2024-04-24T22:27:40.426681974
- id: "TS0003/_TZ3000_wuodqwel"
deviceLabel: TS0003 Switch
manufacturer: _TZ3000_wuodqwel
model: TS0003
deviceProfileName: three-switch
Thanks. Perfect
Looking for support for
Model
AE 264
Type
ZIGBEE
Execution Location
Local
Presentation ID
9a78b42a-368a-3cfe-bca8-1c27fc61ebe1
Manufacturer Name
SmartThingsCommunity
Manufacturer Code
innr
Hello , i am new to samsung smartthings. I have schnider wiser freelocate switch 4k switch zigbee switch⦠https://www.se.com/sg/en/product/E8334RWMZB_WE/wiser-avataron-battery-powered-pushbutton-4k-white/
Looking for edge device driver for smartthings hub v3, Could anybody help us?
Is it possible to add the Azoula 4-in-1 multi sensor information to the Zigbee-Motion-Sensor-v4 driver?
Manual information is identical to information from Post Requests for Zigbee Edge Drivers Here (community-created) - #1406 by Mariano_Colmenarejo.
Right now it shows up as a Illuminance sensor and no options to choose the other driver, unless I am dumb, which I am but that is more general.
Added to this driver version.
Try if it works
Install this driver version in your hub
Do not perform a driver change from current driver
Uninstall device and pair device with this driver version
Name Zigbee Motion Sensor Mc
Version 2024-05-07T21:38:16.193662284
- id: "Sunricher/HK-SENSOR-4IN1-A" # same as Namron
deviceLabel: Sunricher Multi Sensor 4 in 1
manufacturer: Sunricher
model: HK-SENSOR-4IN1-A
deviceProfileName: namron-motion-illuminance-temp-humid
Hello i have a schnider freelocate zigbee switches. i need a edge driver for integration of smartthings hub v3β¦ Can anybody help usβ¦
Hello @mariano_colmenarejo. Could you please add this fingerprint to the zigbee valve driver.
Manufacturer: WAXMAN
Model: leakSMART Water Valve
I see the V2.10 already there but when I add the Valve this is what I get and it gets added as a switch. It works but doesnβt show up as a valve. Your help would be really appreciated.
Hi @res8cowgirl
Name Zigbee Valve Mc
Version 2024-05-11T19:08:10.19967956
- id : WAXMAN/Water Valve
deviceLabel : WAXMAN Valve
manufacturer: WAXMAN
model: leakSMART Water Valve
deviceProfileName: valve-battery-powerSource
Title kind of says it all. I tried using the Zigbee Sensors driver from Yakov, but so far it is not responding correctly, and doesnβt properly update its status (I can shake the device and it will say βNo Vibrationβ). Does anyone have an Edge Driver for this sensor?
Edit:
Model Number:
lumi.vibration.aq1
Manufacturer Code:
LUMI
I have moved your post to the Zigbee request thread. Please read the first post in this thread and then add the details for your request.
Thanks for that!
3 posts were split to a new topic: Coolcam Zigbee CO Alarm? (Tuya)
(Withdrawn by author)
Maybe @iquix can add it to his driver
