Thank you very much, now it is working!
I uninstalled device and all other drivers like zigbee thing mc but the siren was still natively binded as “Generic IAS device”. Then I had to manually change the driver with “Zigbee Siren Mc” (still not responding) and create an automatic simple routine (e.g. if sensor open - then turn on siren) to give it a kick and make it correctly work
Hi @Mariano_Colmenarejo .
IKEA BADRING Water Leakage Sensor.
Could you add the IKEA BADRING to your Zigbee driver?
Hi @cuprumx
Added to this driver version, try if it works
You need install this driver version in your Hub
uninstall device and reinstall device
You do not perform a driver change
Name Zigbee Moisture Sensor Mc
Version 2024-03-17T22:15:22.314239201
- id: "IKEA/BADRING Water"
deviceLabel: IKEA BADRING Water
manufacturer: IKEA of Sweden
model: BADRING Water
deviceProfileName: moisture-battery
@Mang_Kanor_Lang
What is it, smoke or co sensor?
Sorry I forgot to mention it’s a smoke detector
Hi,
Sorry, this device was added some time ago to driver Zigbee Smoke/CO Detector Mc
- id: "_TZ3210_up3pngle/TS0205"
deviceLabel: Smoke Detector
manufacturer: _TZ3210_up3pngle
model: TS0205
deviceProfileName: smoke-battery
Oh I didn’t know, my bad. Thank you Mariano.
I have driver installed:
The device has been uninstalled and reinstalled (several times) but it always detects it first as “Generic IAS Zone” (“Public SmartThings Edge Drivers - w35l3y” and “Default Clusters”) and doesn’t even offer the “Zigbee Moisture Sensor Mc” option.
I wonder if I’m doing something wrong?
I wouldn’t want to remove the w35l3y driver either, because another IKEA device VINDSTYRKA (temperature + humidity + pollen sensor) works more or less with it.
The “Zigbee Thing Mc” driver also fails to display any information when it has selected.
Sorry, I leave half of the model unwritten
Do not perform driver change, pair device with this driver version
Version 2024-03-20T13:21:30.379329271
model: BADRING Water Leakage Sensor
Everything seems to work now!
This “Received Signal Metrics” crap seems to be some kind of bug in the latest Smartthings app update.
Many thanks to you @Mariano_Colmenarejo!
I will fix soon
7 posts were merged into an existing topic: [ST Edge] Personal Tuya Devices - Generic EF00 Device
Hi,
Any chance someone have or can make drivers for these two devices?
Devices as Yaml
Devices:
- Manufacturer: Schneider Electric
Model: FLS/AIRLINK/4
FingerPrinted_EndPoint.Id: 0x15
"App Version": 0x02
"ZCL Version": 0x03
"Network ID": 0x08A3
"Endpoints":
- Id: 0x15
"Server Clusters":
- 0000 # Basic
- 0001 # Power Configuration
- 0003 # Identify
- 0020 # Poll Controll
- FF17 # Schneider Manufacturer specific:
"Client Clusters":
- 0003 # Identify
- 0004 # Groups
- 0005 # Scenes
- 0006 # On/off
- 0008 # Level Control
- 0019 # OTA Update
- 0102 # Window covering
- Id: 0x16
"Server Clusters":
- 0000 # Basic
- 0003 # Identify
"Client Clusters":
- 0003 # Identify
- 0004 # Groups
- 0005 # Scenes
- 0006 # On/off
- Id: 0x17
"Server Clusters":
- 0000 # Basic
- 0003 # Identify
"Client Clusters":
- 0003 # Identify
- 0004 # Groups
- 0005 # Scenes
- 0006 # On/off
- Id: 0x18
"Server Clusters":
- 0000 # Basic
- 0003 # Identify
"Client Clusters":
- 0003 # Identify
- 0004 # Groups
- 0005 # Scenes
- 0006 # On/off
- Manufacturer: NAMRON AS
Model: 4512703
FingerPrinted_EndPoint.Id: 0x01
"App Version": 0x00
"ZCL Version": 0x03
"Network ID": 0x2487
"Endpoints":
- Id: 0x01
"Server Clusters":
- 0000 # Basic
- 0003 # Identify
- 0B05 # Diagnostics
- 1000 # Touchlink commissioning
"Client Clusters":
- 0003 # Identify
- 0004 # Groups
- 0005 # Scenes
- 0006 # On/off
- 0019 # OTA Update
- 0300 # Color Control
- Id: 0x02
"Server Clusters":
- 0000 # Basic
- 0003 # Identify
"Client Clusters":
- 0003 # Identify
- 0004 # Groups
- 0005 # Scenes
- 0006 # On/off
- 0019 # OTA Update
- Id: 0x03
"Server Clusters":
- 0000 # Basic
- 0003 # Identify
"Client Clusters":
- 0003 # Identify
- 0004 # Groups
- 0005 # Scenes
- 0006 # On/off
- 0019 # OTA Update
- Id: 0x04
"Server Clusters":
- 0000 # Basic
- 0003 # Identify
"Client Clusters":
- 0003 # Identify
- 0004 # Groups
- 0005 # Scenes
- 0006 # On/off
- 0019 # OTA Update
For the elko (Schneider Electric) one, I have found the zigbee implmentation document, but the endpoints (0x15…18) do not match up to the documented ones (0x21…24), although the model name does, I might have an older firmware/model, my assumption is that it would still work as documented.
This can be configured as a 1-gang, 2-gang or 4 button switch. The manufacturer specific cluster 0xFF17 which controls the mode of the device is also very well documented in the attached document.
The Namron switch, was mentioned over here previously Gettings started - Simple explanation needed for multibutton.
It is a 4 channel/group switch with 8 buttons, one channel having two buttons with one on and one off button. It matches the Vesternet VES-ZB-WAL-012 device, but their smartthings DTHs were scrubbed(?), and the edge drivers are currently closed source (they do provide an edge driver channel though).
Their hubitat groovy drivers are still published to github, but without a license hubitat-zigbee-device-drivers/Vesternet VES-ZB-WAL-012 4 Zone Wall Controller.groovy at main · vesternet/hubitat-zigbee-device-drivers (github.com)
The old smartthings DTH I have a copy of here VesternetSTDeviceHandlers/Vesternet VES-ZB-WAL-012 4 Zone Wall Controller.groovy at main · frehov/VesternetSTDeviceHandlers · GitHub
@MartynWendon Any chance that you are the same person as on the Vesternet github? Would it be at all possible for you to publish the source for the vesternet edge drivers, or possibly include the namron fingerprint into the Vesternet driver? I understand this might be a very big ask, and do understand if it is not possible.
@Mariano_Colmenarejo hi, any chance you can add this device to your drivers?
Aqara E1 motion and illuminance sensor RTCGQ15LM
Manufacturer:LUMI
Model: lumi.motion.acn001
Hi,
Sorry, this device use custom clusters and does not work with standard driver
@Mariano_Colmenarejo, Please can you add this fingerprint for the Zigbee smart button to your driver? It gets added as a generic switch for some reasons and creates 3 child switches as well.
Sorry, I don’t have any drivers for multiple zigbee buttons.
Sorry, what do you mean by multiple Zigbee buttons, I have only one button
