Hi,
I am looking for an edge driver for the Moes presence sensor - it doesnβt use EF00 cluster.
Can someone help?
Thanks.
Hi,
Can someone help?
Thanks.
@Henrik_W is there a channel we can subscribe to and download the driver?
Hi, Iβm looking for a driver for Maxcio (Tuya) Water Sensor
Model: TS0207
Manufacturer Code: _TZ3000_vbznqafr
Hi @TonyL
Added to this driver version
Install this driver version in your hub
uninstall device and reinstall device for correct configuration
Do not perform a driver change from Zigbee Thing Mc
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Moisture Sensor Mc
Version 2024-02-22T20:27:33.628757181
- id: "_TZ3000_vbznqafr/TS0207"
deviceLabel: TS0207 Water Sensor
manufacturer: _TZ3000_vbznqafr
model: TS0207
deviceProfileName: moisture-battery
Iβm looking for a driver for Model LKMSZ001 manufactured by Tuya
Zigbee ID: TS0202 | _TZ3210_cwamkvua
Column 1 | Column 2 | Column 3 | Column 4 |
Manufacturer | _TZ3210_cwamkvua | ||
Model | TS0202 | ||
Endpoint | 0x01 | ||
Device ID | 0x0402 | ||
Network ID | 0x9B05 | ||
Profile ID | 0x0104 | ||
Server Clusters | |||
PowerConfiguration | 0x0001 | 0x01 | |
? | 0xEF00 | 0x01 | |
Basic | 0x0000 | 0x01 | |
IASZone | 0x0500 | 0x01 | |
Client Clusters | |||
Time | 0x000A | 0x01 | |
OTAUpgrade | 0x0019 | 0x01 |
Please read the first post in this thread carefully. It is not enough to give the model number, you have to give the βfingerprintβ as SmartThings will see it, and determine which clusters it uses.
FAQ: Using Tuya Zigbee Devices Directly With a SmartThings/Aeotec Hub (2024)
Iβm sorry, my bad, I suspect itβs one of those EF00 , Iβll update shortly
Updated @JDRoberts 0xEF00 0x01 confirms itβs one of those right? TIA
Hi @Alvarofg
This device use cluster EF00 and standard 0500 y 0001, it may work with the standard driver
Name Zigbee Motion Sensor Mc
Version 2024-02-25T09:57:48.84168975
- id: "_TZ3210_cwamkvua/TS0202"
deviceLabel: TS0202 Motion Sensor
manufacturer: _TZ3210_cwamkvua
model: TS0202
deviceProfileName: motion-battery
11 posts were split to a new topic: Help needed with Zigbee thing driver
Thank You. I hope it will work.
Thanks so much for the RODRET driver! Worked for my button after a few attempts and that encouraged me to package my own driver. I found out the Identify cluster or refresh handling isnβt needed, just the bind to Level in the do_configure will do.
While Iβm not a SmartThings developer (so donβt expect much support) I created a driver channel to install the driver that hopefully will be useful to others.
Edit: Iβve also included SOMRIG support and battery reporting works too for both RODRET and SOMRIG:
Hi, wondering if someone could point me in the right direction. Iβve been unable to locate an edge diver that works with this generic Tuya Zigbee βbasic-buttonβ/βswitchβ?
Manufacturer: _TZ3000_an5rjiwd
Model: TS0041
FingerPrinted_EndPoint.Id: 0x01
App Version: Unknown
ZCL Version: Unknown
Network ID: 0xFEAD
Zigbee EUI: A4C1382A301A033C
Device ID: c4f4ed3e-ab70-43ed-b6ab-8327567106b9
Server Cluster:
Ep: 0x03={ 0006,0001,0006 }
Ep: 0x04={ 0006,0001,0006 }
Ep: 0x01={ 0001,0006,E000,0000 }
Ep: 0x02={ 0006,0001,0006 }
Client Clusters:
Ep: 0x01={ 0019,000A }
Thanks!, motions seems to be working with your driver. No light (dark, bright) or action (when the button is clicked), also battery is showing 0%.
Are you perform this procedure to device configure?
illuminance could use EF00 cluster and does not work with this driver
yes, after I installed the driver, I removed the device and added it again. It show up as a TS0202 Motion sensor.
Dear @Mariano_Colmenarejo thank for adding TS0202 Motion sensor to your list, just to check is it possible to change the Default motion sensor interval report from 300 to minimum (1 second to 3600) as the default is 300 Sec.
Sir
Hi @Yihuii89
Sorry, reduce the interval report of 300 sec may will drop battery life and saturate your zigbee network
I just bought an AduroSmart Eria siren because I saw the brand in the partner devices but itβs not working.
None of the driver I found is making it work properly (Zigbee siren, Zigbee siren Mc, personal Tuya devices - main)
I used Zigbee thing Mc to obtain the following info:
@Mariano_Colmenarejo Could you add AduroSmart Eria Siren to your driver
Hi,
You need install this driver version in your Hub
You do not perform a driver change
Name Zigbee Siren Mc
Version 2024-03-08T18:32:19.482589636
- id : AduroSmart/Siren
deviceLabel : AduroSmart Eria Siren
manufacturer : AduroSmart Eria
model : Smart Siren
deviceProfileName : switch-alarm
