Here is a DTH that I was using for the Lightify 4 button switch back in 2017.
metadata {
definition (name: “OSRAM 4 Button Switch Classic”, namespace: “AnotherUser”, author: “AN”) {
capability "Actuator"
capability "Battery"
capability "Button"
capability "Configuration"
capability "Refresh"
capability "Sensor"
attribute "zMessage", "String"
fingerprint profileId: "0104", deviceId: "0810", inClusters: "0000, 0001, 0020, 1000, FD00", outClusters: "0003, 0004, 0005, 0006, 0008, 0019, 0300, 1000", manufacturer: "OSRAM", model: "Switch 4x-LIGHTIFY", deviceJoinName: "OSRAM 4x Switch"
simulator {
// Nothing to see here
tiles(scale: 2) {
standardTile("button", "device.button", width: 6, height: 4) {
state "default", label: "", icon: "st.unknown.zwave.remote-controller", backgroundColor: "#ffffff"
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
state "battery", label:'${currentValue}% battery'
standardTile("refresh", "device.button", decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
main "button"
details(["button", "battery", "refresh"])
log.debug “Parsing ‘${description}’”
// TODO: handle ‘numberOfButtons’ attribute
// Parse incoming device messages to generate events
Map map = [:]
log.debug "parse description: $description"
if (description?.startsWith('catchall:')) {
// call parseCatchAllMessage to parse the catchall message received
map = parseCatchAllMessage(description)
} else if (description?.startsWith('read')) {
// call parseReadMessage to parse the read message received
map = parseReadMessage(description)
} else {
log.debug "Unknown message received: $description"
//return event unless map is not set
return map ? createEvent(map) : null
def configure() {
log.debug “Confuguring Reporting and Bindings.”
def configCmds = [
// Bind Button 1 and 2. No Change from source.
“zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0006 {${device.zigbeeId}} {}”,
// Bind Button 3 and 4. New cluster IDs.
“zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0300 {${device.zigbeeId}} {}”,
// Bind the outgoing level cluster from remote to hub, so the hub receives messages when Dim Up/Down buttons pushed
“zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0008 {${device.zigbeeId}} {}”,
// Bind the incoming battery info cluster from remote to hub, so the hub receives battery updates
“zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0001 {${device.zigbeeId}} {}”,
//ToDO: Determine what other clusters are on there and how they can be used. What purpose do 0003, 0004, 0005, 0019, and 1000 have?
“zdo bind 0x${device.deviceNetworkId} 0x02 0x01 0x0006 {${device.zigbeeId}} {}”,
“zdo bind 0x${device.deviceNetworkId} 0x03 0x01 0x0006 {${device.zigbeeId}} {}”,
“zdo bind 0x${device.deviceNetworkId} 0x04 0x01 0x0006 {${device.zigbeeId}} {}”,
“zdo bind 0x${device.deviceNetworkId} 0x02 0x01 0x0300 {${device.zigbeeId}} {}”,
“zdo bind 0x${device.deviceNetworkId} 0x03 0x01 0x0300 {${device.zigbeeId}} {}”,
“zdo bind 0x${device.deviceNetworkId} 0x04 0x01 0x0300 {${device.zigbeeId}} {}”,
return configCmds
def refresh() {
//Straight copy. Need to check device and clusterID for battery.
def refreshCmds = [
zigbee.readAttribute(0x0001, 0x0020)
//when refresh button is pushed, read updated status
return refreshCmds
private Map parseReadMessage(String description) {
// Create a map from the message description to make parsing more intuitive
def msg = zigbee.parseDescriptionAsMap(description)
//def msg = zigbee.parse(description)
if (msg.clusterInt==1 && msg.attrInt==32) {
// call getBatteryResult method to parse battery message into event map
def result = getBatteryResult(Integer.parseInt(msg.value, 16))
} else {
log.debug “Unknown read message received, parsed message: $msg”
// return map used to create event
return result
private Map parseCatchAllMessage(String description) {
// Create a map from the raw zigbee message to make parsing more intuitive
def abc = “zdo active 0x${device.deviceNetworkId}”
log.debug “cluster ID is $msg.clusterId”
log.debug “message from source $msg.sourceEndpoint”
//New content follows
switch(msg.sourceEndpoint) {
//Endpoint numbering runs top left, top right, lower left, lower right.
case 1: //“physical button 1”
Map result = [:]
if (msg.command==01){
result = [
value: ‘pushed’,
data: [buttonNumber: 1],
descriptionText: “$device.displayName button 1 was pushed”,
isStateChange: true
else if (msg.command==05) {
result = [
value: ‘held’,
descriptionText: “$device.displayName button 1 was held”,
isStateChange: true
else if (msg.command==03) {
result = [
value: ‘stophold’,
descriptionText: “$device.displayName button 1 stopped being held”,
isStateChange: true
log.debug "Parse returned ${result?.descriptionText}"
return result
break
case 2: //physical button 3
Map result = [:]
if (msg.command==76){
result = [
value: 'pushed',
data: [buttonNumber: 3],
descriptionText: "$device.displayName button 3 was pushed",
isStateChange: true
else if (msg.command==03){
result = [
value: 'held',
descriptionText: "$device.displayName button 3 started to be held",
isStateChange: true
else if (msg.command==01){
if(msg.data[0]==1){
result = [
value: 'longhold',
descriptionText: "$device.displayName button 3 continued to be held",
isStateChange: true
else if (msg.data[0]==0){
result = [
value: 'stophold',
descriptionText: "$device.displayName button 3 stopped being held",
isStateChange: true
else{
result =[
descriptionText: "$device.displayName button 3 unknown data in command 01",
else{
result =[
descriptionText: "$device.displayName button 3 unknown command",
log.debug "message data $msg.data[0]"
log.debug "message command $msg.command"
return result
break
case 3:
//physical button 2
Map result = [:]
result = [
value: 'pushed',
data: [buttonNumber: 2],
descriptionText: "$device.displayName button 2 was pushed",
isStateChange: true
return result
break
case 4:
//physical button 4
Map result = [:]
result = [
value: 'pushed',
data: [buttonNumber: 4],
descriptionText: "$device.displayName button 4 was pushed",
isStateChange: true
result = [
value: 'held',
descriptionText: "$device.displayName button 4 started to be held",
isStateChange: true
if(msg.data[0]==3){
result = [
value: 'longhold',
descriptionText: "$device.displayName button 4 continued to be held",
isStateChange: true
result = [
value: 'stophold',
descriptionText: "$device.displayName button 4 stopped being held",
isStateChange: true
else{
result =[
descriptionText: "$device.displayName button 4 unknown data in command 01",
else{
result =[
descriptionText: "$device.displayName button 4 unknown command",
return result
break
//ToDo: Look at how to capture hold down of buttons 3 & 4, it doesn’t differentiate on cluster or command as per B1 and B2 .
//Motley obtained from other examples, converts battery message into event map.
//AN: I don’t think this is working yet.
private Map getBatteryResult(rawValue) {
def linkText = getLinkText(device)
def result = [
value: ‘–’
def volts = rawValue / 10
def descriptionText
if (rawValue == 0) {
} else {
if (volts > 3.5) {
result.descriptionText = “${linkText} battery has too much power (${volts} volts).”
} else if (volts > 0){
def minVolts = 2.1
def maxVolts = 3.0
def pct = (volts - minVolts) / (maxVolts - minVolts)
result.value = Math.min(100, (int) pct * 100)
result.descriptionText = “${linkText} battery was ${result.value}%”
log.debug “Parse returned ${result?.descriptionText}”
return result
