+1 for Eurotronic Spirit Zigbee TRV
The documentation below includes cluster detail etc.
https://eurotronic.org/wp-content/uploads/2021/07/Spirit_ZigBee_BDA_web_EN_2021.pdf
Please take questions/comments about a specific driver to the author thread for that driver. This thread is only for a request for a new driver.
In this case:
(EDGE Driver-Mc): Zigbee Temp Sensor and Child Thermostat Mc, Zigbee Temp Sensor with Thermostat Mc
Developers:
Please respond with a link to your author thread and continue the conversation there. Thank you.
@Mariano_Colmenarejo Thank you for everything you have done to support the ST community! I had preveously enrolled in your βMariano Shared Beta Driverβ channel on my hub for a couple of other devices, including the βZigbee Switch Mcβ driver. But it did not allow me to enroll my Outlink. That is we I made my post.
Shortly after you sent your message I deleted and attempted to reenroll the Outlink, but had the same outcome - It onboards as a βZ-Wave Controllerβ apparently using a Groovy DTH, as no βDriverβ option appears in the device menu option.
I understand that changes to drivers can take up to 12 hrs, and so I waited overnight to reattempt to delete and add the device, but still the same result. Below is the βZigbee Switch Mcβ driver information as of right now -
The device is an in-wall outlet (receptacle) -
It was power monitoring capabilities, but all I want to do is to control it, On and Offβas before with the Mitch Pond DTHβusing a Routine, based on a motion detector.
Anything else you can do to restore the use of this device would be highly appreciated.
Thank you.
Hi @manuelceja
Added to this driver version
Install Zigbee Switch Power Mc driver from my channel
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Switch Power Mc
Version 2022-12-20T16:48:50.041785547
- id: "Quirky/ZHA Smart Plug"
deviceLabel: Smart Plug
manufacturer: Quirky
model: ZHA Smart Plug
deviceProfileName: switch-power-energy-plug
It works! Thank you, so very much!
I deleted the incorrect βZ-Wave Controllerβ device. I then added the βZigbee Switch Power Mcβ driver, and I attempted to add a device by scanning for nearby device, and it immediately added it.
I tested via the app and on the device, and they sync up perfectly. I have also added it back to my routines.
You are a gifted and generous individual - Thank you for restoring this device to our setup!
Hello all,
Is there any chance I can get an edge driver for:
Is 2 gang switch, and @Mariano_Colmenarejo drivers does not recognize it (I also have 1, 2 and 3 way switch from same manufacturer, excepting 1 gang, the rest are not recognized)
Hi @Kowalski
Added 2 gang switch to this driver version
If you send the fingerprints for other 1 and 3 gang switch then I will add
Name Zigbee Multi Switch and Child Mc
Version 2022-12-21T14:02:25.597718005
- id: "TS0002/_TZ3000_ptjcjise"
deviceLabel: Two Switch
manufacturer: _TZ3000_ptjcjise
model: TS0002
deviceProfileName: two-switch
I did see that but that iss for treat life hub or wifi devices. The device Iβm trying to join is zigbee
This is 3 gang switch
This is 1 gang switch
Thank you a lot for all your magic done for ST community.
Hi @Kowalski
Version 2022-12-21T22:12:49.863103217
- id: "TS0003/_TZ3000_jfha4mdia"
deviceLabel: TS0003 3 Switch
manufacturer: _TZ3000_jfha4mdia
model: TS0003
deviceProfileName: three-switch
Name Zigbee Switch Mc
Version 2022-12-21T22:17:15.633277908
- id: "_TZ3000_0t4zjtia/TS0001"
deviceLabel: TS0001 Switch
manufacturer: _TZ3000_0t4zjtia
model: TS0001
deviceProfileName: single-switch
Damn that was fast ![]()
Thanks again sincerely for all your effort done for this community.
Does anyone know some zigbee devices appears as βExecution Cloudβ in api.smartthings.com/device/list
Even tho they use edge drivers? (even Samsung Official zigbee edge drivers, some appears to run as Cloud instead of Local)
IDE was designed for groovy devices and smartapps so it does not display info for Edge devices. They only show Placeholder and Cloud but directly connected Edge devices are running locally. FYI - IDE will cease on December 31.
See the community FAQ:
FAQ: Why does the IDE list βplaceholderβ for my device? Can I change that?
Hi there, newbie in here so hope it is OK to ask.
Was hoping for this driver to help me get paired a simple PIR-motion detector, but no luck.
Have seen in the βfingerprintsβ list that my device is a little different from others in that list. It seem to be some kind of Tuya make with same model number as many others RH3040. But it is named Qnect SH-ZS03-QNE at the labels.
Any possibility to add this manufacturer ID also in your driver please?
I attach a screenshot from info found inside Smartthings app after paired as a Zigbee-Thing.
Hi @Nettulf
Tomorrow i Will add your device to zigbee Motion Mc
That was really fast, thank you! ![]()
Morning @Mariano_Colmenarejo, 1 and 2 gang works perfectly, except 3 gang switch, It does not see it, perhaps didnβt propagate yet, but not sure about that, as if both of them were published at same time (1 and 3 gang)
Any suggestions?
PS, I already restarted the hub, not sure if that helps, but I did it just in case, and still canβt see it (except as a thing)
