Post Requests for Zigbee Edge Drivers Here (community-created)
If you have a Hue hub, these outlets are already supported. The driver I have posted supports them, and I think the stock ST driver also does. ST will be converting theirs to Edge at some point as well. Here is the one I have been developing:
I don’t have a hub, just added another last night and it still used the native ZigBee switch dth instead of the ZigBee switch edge driver. I have both the native and the MC edge drivers installed.
I only have hue outlets and motion sensors no bulbs so my hue hub has been buried in a box for over a year. I have even installed Sonoff Zbmini devices in all my stand alone lamps so no need for smart bulbs.
Hi @David_Kneebush
If You want i could add to zigbee switch Mc tomorrow
Thanks, that would be great!
Hi @David_Kneebush
Added to this driver version
 Name         Zigbee Switch Mc
 Version      2022-12-18T10:05:08.440175774
- id: "Philips Hue Plug/LOM010"
    deviceLabel: Philips Hue Plug
    manufacturer: Signify Netherlands B.V.
    model: LOM010
    deviceProfileName: single-switch-plug
Thanks, Mariano. Just converted both…they are both running space heaters controlled by Aquara Temp sensors using your Thermometer with virtual Thermostat driver to keep my Michigan basement warm.
Hi Community
I have zigbee thermostats from Sinope (model TH1123ZB-TH1124ZB). One my thermostat is now on the official zigbee thermostat edge driver (but not the others). The driver work really fine but with the update, we lost some features. First feature, is the outside temperature shown on the display of the thermostat. I know that to get the temperature, the thermostat must contact a web service so it’s not really a local feature.
Second feature, is the display of the time on the thermostats. I don’t know why the feature disappear because time is suppose to be a local value on the hub. It’s really pratical to have the time on the thermostat
So if it’s possible to do something about that it would be appreciate.
There is the raw discription for both model:
TH1123ZB: 01 0104 0301 01 0B 0000 0003 0004 0005 0201 0204 0402 0702 0B04 0B05 FF01 03 000A FF01 0019
TH1124ZB: 01 0104 0301 00 0A 0000 0003 0004 0005 0201 0204 0402 0B04 0B05 FF01 02 FF01 0019
There is the DTH code from the thermostats (if the can help you):
Thank you very much
Hi @Mariano_Colmenarejo ,
I have a SYLVANIA General Lighting 73773 Full Color Lighting Kit Sylvania Smart+ ZigBee Flex XL Indoor Lightstrip
product link
I enrolled the zigbee switch then delete the device, re-paired it but it still used the old driver. Is this driver also support this lightstrip?
The following is the lightstrip information
  • application: 01
  • endpointId: 01
  • firmwareFullVersion: 00102411
  • firmwareImageType: 9
  • firmwareManufacturerCode: 4489
  • manufacturer: LEDVANCE
  • model: Flex XL RGBW
  • zigbeeNodeType: ROUTER
Thank you
Hi @msazone
 Name         Zigbee Light Multifunction Mc
 Version      2022-12-19T16:36:25.38664716
- id: "LEDVANCE/Flex XL RGBW"
    deviceLabel: LEDVANCE Flex XL RGBW
    model: Flex XL RGBW
    deviceProfileName: rgbw-level-colortemp-2700-6500
Thank you so much @Mariano_Colmenarejo
I have attempted to do my homework, both in troubleshooting and searches, but have been unsuccessful in finding a solution.
Is there an edge driver available for the originally Wink-based GE/Quirky Outlink in-wall switch?
I was preveously with the DTH created by Mitch Pond to control this device.
It has been misbehaving for the last several hub firmware updates, and decided to try an force the migration to an edge driver assuming I could use either a generic or GE-based default driver to get it to be stable. Neither has been true.
I have the Aeotec V3 hub. I deleted the device and have made multiple (10+, more?) attempts to add it and it appears as a β€œZ-Wave Controller Device” each time, although it is a zig bee device!
I have tried numerous troubleshooting steps (restarting hub, clearing unused drivers, etc,) but it does not register correctly. I assume that there is either some other problem present with my system (hub/device/other), but that if there is a correct edge driver available it should work - ?
Any help to locate or create the appropriate edge driver for the Outlink would be highly appreciated.
In addition to this device I have eight others (GoControl contact/motion/siren & Wink/Quirky Trippers) on DTH’s that I am also not able to locate edge drivers for, and I am hoping that they will be automatically, successfully migrated, but have low hopes if that actually occuring.
Thank you for your help!
I wish more than anything I could control my Yamaha Musiccast system and my Big Ass Fans with SmartThings!
Hi @manuelceja
I have added a Quirky Smart Switch to the Zigbee Switch Mc driver.
If you want I can add this of yours ZHA Smart Plug to the Zigbee Switch Power M driver, since it has cluster 0702 and could work for power and energy.
Is it a plug or a switch?
+1 For this request
Just wondering @Mariano_Colmenarejo if its at all possible to have a driver for Aqara Temperature/humidity sensor without the thermostat stuff?
I had 1 Aqara sensor using the driver β€œZigbee Temp Humidity Sensor MC-(OLD)” which i loved the tiles layout, but all my newly added sensors only have the β€œZigbee Temp Sensor with Thermostat Mc” available, this one’s tile layout isnt as good and or useful.
Totally understand if this isnt possible.
Chris
Hi @Ace2
If you don’t want to use the virtual thermostat child, don’t create the thermostat device from preferences.
That way the driver will work exactly the same as the previous one. It will not run any thermostat routines.
You can use the multiple tiles too just like before
@Mariano_Colmenarejo I dont have a option to create without thermostats, I’ve added the sensor by searching for device in Smartthings and it chooses the edge driver.
If i goto select different drivers, i have these :
In smartthings im present with this
Am i missing something?
Is ther a driver for the Aqara roller shade driver E1
+1 for Eurotronic Spirit Zigbee TRV
The documentation below includes cluster detail etc.
https://eurotronic.org/wp-content/uploads/2021/07/Spirit_ZigBee_BDA_web_EN_2021.pdf
Please take questions/comments about a specific driver to the author thread for that driver. This thread is only for a request for a new driver.
In this case:
(EDGE Driver-Mc): Zigbee Temp Sensor and Child Thermostat Mc, Zigbee Temp Sensor with Thermostat Mc
Developers:
Please respond with a link to your author thread and continue the conversation there. Thank you.
