Interesting because they are not being picked up and are provisioning with a groovy z-wave repeater ¯_(ツ)_/¯
Those Z-Wave fallback integrations are a menace as they use very spartan fingerprints that overlap with Zigbee and there have been a number of reports of them being used when there should be better matches.
In this case it would have to be the beta driver as the specific Sengled model isn’t fingerprinted for the default channel yet.
Yea I have the beta channel added to my hub
Is it possible to write edge driver for Ikea STARKVIND Air Purifier? I manage to get it working before with DHT from a fan (only power and speed).
It lists these states as available: fan (state, mode), fan_speed, pm25, air_quality, led_enable, child_lock, replace_filter, linkquality
Here is a link if it’s any help:
Or this: Starkvind Air purifier · Issue #350 · home-assistant-libs/pytradfri · GitHub
Good afternoon . @veonua @ygerlovin ould you please add the fingerprint to the Zigbee contact driver of the Aqara P1 door and window sensor, model MCCGQ13LM , It is zigbee 3.0. Below is the print of the Zigbee Thing fingerprint of this sensor model.
https://pt.aliexpress.com/item/1005004956147723.html?spm=a2g0o.productlist.0.0.2cb75980ialwNI&algo_pvid=93591cec-c9b6-4eb6-9e28-e5d21039334a&aem_p4p_detail=202212061633111327700753328000001147833&algo_exp_id=93591cec-c9b6-4eb6-9e28-e5d21039334a-0&pdp_ext_f={"sku_id"%3A"12000031148788889"}&pdp_npi=2%40dis!BRL!186.12!141.48!!!!!%40210318c216703731916663284e7de7!12000031148788889!sea&curPageLogUid=qb4xBdyljuQz&ad_pvid=202212061633111327700753328000001147833_1&ad_pvid=202212061633111327700753328000001147833_1
Hello
Is it possible to add this 4-button remote?
Manufacturer: _TZ3000_u3nv1jwk
Model: TS044
Server cluster:
Ep:01={0000,0001,0006}
Ep:02={0001,0006}
Ep:03={0001,0006}
Ep:01={0001,0006}
Client cluster:
Ep:01={0019,000A}
SMATRUL Tuya ZigBee Wireless Smart Home Scene Switch Light 4 Gang 12 Scene Touch Light Switch Remote Control Smart Life App
https://a.aliexpress.com/_mrs7aQe
I am requesting a driver for a Zemismart roller blind that uses a model BSDJ-ZM25EL-08/25-ZB tubular motor. It is a Tuya Zigbee motor. Here is the product link for the Zemismart site: Zemismart Tuya Zigbee 3.0 Roller Shade Motor with Battery For 38mm Tube Smart Life APP Control ALexa Google Home Control
I had asked Zemismart if they planned on updating their device handler to Edge and they stated they had not plans to write a driver. Here is the Custom Device handler Raw Code that I was operating under.
GitHub Repository:
- Owner: shin4299
- Name: XiaomiSJ
- Branch: master
NOTE: I deleted the blind and the Custom DTH to attempt to install the blind driver and it just came up as a ‘Zigbee Thing’ using the ‘Zigbee Thing [YG] v1.0.2’ Driver which is not working. See below:
Can anyone direct me to the appropriate Edge Driver?
That’s using the Tuya proprietary EF00 cluster, so you will have to find an edge driver for that specific fingerprint.
The community developer is going to need the full manufacturer name— your screen print has cut off the right side of it. Tuya stores model information in the manufacturer name field. ![]()
Doe anyone have an edge driver for the Treatlife Wifi Smart Ceiling Fan Control and Dimmer Light Switch?
You should not need a driver since this is a cloud to cloud (c2c) integration.
Looking for Iris keypad 3405-L Edge driver. Thank you
Not sure if this is the right place but i havent been able to find any edge drivers for my Mercator Outdoor Double Power Point/Outlet. I’ve managed to add it via SmartThings but under groovy ide. It has added it as ZigBee Switch Power when logging into SmartThings ide. Only problem is that upon testing it i can only control one power point/outlet.
The link below is what the product is: Double Power Point IP54 | Ikuü
Below is the Data from smartthings IDE
- application: 4A
- endpointId: 01
- firmwareFullVersion: 0000004A
- firmwareImageType: 5634
- firmwareManufacturerCode: 4098
- manufacturer: _TZ3210_7jnk7l3k
- model: TS011F
- zigbeeNodeType: ROUTER
Raw Description 01 0104 0051 01 08 0000 0004 0005 0006 0702 0B04 EF00 0003 02 0019 000A
I’m relatively new to all this so apologies if i missed anything or posted in the wrong place. I was wondering if there is an existing edge driver i can try?
I am requesting edge driver for the Tuya mmwave human presence sensor. I do not have model number at this point. I believe it is manufactured by Wenzhi from what I have found on Aliexpress.
You will need the model number and the complete “fingerprint”, but there have already been multiple different requests including in this thread. It’s a cool device, but A community developer has looked at it and it uses proprietary Tuya clusters, and those can be very challenging to develop for. Most of those models did not work with the old smartthings platform and I’m not sure they are going to work with the new one, either. ![]()
See the following recent discussion:
BTW, if you haven’t bought it, yet, there is an edge driver that works with most of the features of a similar device from Aqara, the FP1. It doesn’t have the proprietary code issues that the Tuya model does.
Thanks for the link to this previous information. Sometimes it’s hard to find what you are looking for on the site. TMI ![]()
Hue outlet are the last item in my system without an edge driver.
- Last Hop LQI: 198
- Last Hop RSSI: -84
- Received Messages From Device: 236
- Received Messages From Device (Duplicates): 1
- Messages Transmitted to Device: 85
- Messages Transmitted to Device (Failures): 0
- Updated Time: 2022-12-17 11:12 AM EST
Data * application: 02 - endpointId: 0B
- firmwareFullVersion: 01000604
- firmwareImageType: 282
- firmwareManufacturerCode: 4107
- manufacturer: Signify Netherlands B.V.
- model: LOM010
Raw Description 0B 0104 010A 01 08 0000 0003 0004 0005 0006 0008 1000 FC02 01 0019
Tagging @blueyetisoftware
