Yes…in the second section down on the scenario where you choose your switches…Volume When Speaker Turned On
I will be curious if this works for you, but I just tested without anything outside of an Alexa Switch and the speaker and it works great…I assume this IS a Sonos and it works through the normal SmartThings control (i.e. it is integrated in completely? I can’t get mine to fail…
I would also recommend you are using all of the correct versions, and worst case, uninstall Alexa Helper and reinstall it and create a new speaker scenario.
well, it is a sonos but I use non-standard device type.
I use the media renderer device type from:
And I’ve tested volume with this device type . IT doesn’t work.
So it is a problem of Media Renderer device type.
I don’t know how to fix it though.
Ah…that explains it…BUT it should be fixed in your put in an initial volume into your app…right now if you don’t have that it polls the speaker and gets its volume and puts that into the dimmer…If you have a non standard device the ‘get level’ command may not work.
I understand that this should be fixed on the device handler I use.
(above - generic media renderer)
I hope the author helps me about this…
Yes…in theory…but it may not be as simple to poll the device.
Let me know if the author does not fix it…I think there is a way (with your help) that I can put in some code to at least check for your use case…in theory that command is optional and is only used to keep the virtual dimmer in sync.
actually the volume control on ST device does not work for me with this device handler.
I need a fix on the device handler in any case.
Ah…ok…let me noodle on this for a bit, but I think I know how I can gracefully trap this error and still allow you to ‘play’. Will PM you with a beta copy this week.
thanks.
maybe you can also check the media renderer device handler
I bet it is an easy fix for you if you could analyze the code.
I could not see any errors in the log (for media a renderer) so I am not able to move further.
Did you actually set the volume within the Alexa Helper scenario? I am curious if the ‘setLevel’ works at all with the media renderer.
yes it works that way.
Ok…I know of a way to error trap this then…stand by…
try this…this basically traps the setLevel command, and sends a note to the log if it can’t set the level…you MIGHT get an error at 530, but that is a good sign if you do…
Let me know how this works…this will give me the basic of making a change to the code that should allow for other speakers to be accommodated:
https://raw.githubusercontent.com/MichaelStruck/SmartThings/master/Other-SmartApps/AlexaHelper/beta
so you just added this with a try_catch loop:
if (speakerInitial){
def speakerLevel = speakerInitial as int
try{
vDimmerSpeaker.setLevel(speakerLevel)
catch(e){
log.debug "Can't set level...speaker will play at current level"
I’ve installed this version but I can’t test it now. I will tell you tomorrow.
What shall I expect from this one ?
The expectation is that it will actually play something, or error out at line 530…but either way it will tell me that trapping the setlevel is the proper way to do this.
I don’t know what happened but now I am getting this error when turning on
c8961620-eb45-4212-8cde-384fcb0cf970 07:43:23: info Alexa Helper scenario 'Test', 'Speaker on/off' triggered
b3e71620-0ce5-4200-aa1d-b44dc01be24c 07:43:22: info Alexa Switch sent 'Off' command
c8961620-eb45-4212-8cde-384fcb0cf970 07:43:17: error org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'int'. Try 'java.lang.Integer' instead @ line 511
c8961620-eb45-4212-8cde-384fcb0cf970 07:43:17: info Alexa Helper scenario 'Test', 'Speaker on/off' triggered
b3e71620-0ce5-4200-aa1d-b44dc01be24c 07:43:16: info Alexa Switch sent 'On' command
I actually transposed which command I was trapping…I fixed it…feel free to give it another shot (same code location).
you’ve missed a bracket “}” there.
anyway it is working now. thanks.
what about my getvolume/setvolume problem ?
how can I solve it ?
Opps…I did indeed…thanks for the fix there, but glad it works. I will integrate this into the main app in the various areas so it should work for setting the volume…will send you a beta test to look at later this week.
To be clear, all of your issues are now fixed using the switch with the speaker? I was just going through the code and don’t see any other instances where I am calling volume from the speaker. When you say [quote=“mrmrmrmr, post:38, topic:41987”]
what about my getvolume/setvolume problem ?how can I solve it ?
[/quote]
Are you talking about overall with the media player integration? That would have to be handled by ULE. I did look through the media device code, and he doesn’t call out currentValue specifically; however, he DOES call out getVolume which might work. If you do speak with him just let him know you are looking to get the current device level with the currentValue(“level”) command…it does look like it might be easy for him to add in.
If you are still getting errors with Alexa Helper, let me know.
