Phone alarm clock as a trigger?
Hi, I have already integrated most of the stuff, unfortunately I still have a problem left. I previously used home asisstant and there I had a trigger set which was the alarm clock on my phone. How do you replicate this in SmartThings? I would like the corresponding automation to trigger when the alarm clock on the phone goes off. Do you have any ideas on how to do this?
Brand and model of your phone? It’s easier to do with some phones than others.
huawei p20 pro and realme gt master edition, in both android and google play
Tagging @joshua_lyon to check if SharpTools.io is an option for this
You could use Tasker to react to the alarm events on the phone and then either use the SharpTools Tasker plugins to control a SmartThings device or the Tasker HTTP action to call a SharpTools.io Rule Engine rule.
If you have Google assistant linked to Smartthings and have the Google Clock app on your phone you can have an alarm trigger Google Assistant and any ST devices that show up in Google Assistant.
I use it to turn on lights and start my coffee when my morning alarm goes off.
No option in Google clock, maybe disappeared with update?
Open Google clock, set alarm, pick Google Assistant.
I don’t have that option unfortunately…
What version of android are you running? I am running as android 13, but I believe I had the same options with android 11.
S9+, android 10, OneUI 2.5
But apparently it worked before, maybe it’s regional thing as I’m in EU, Czechia?
Could be regional. I am in the US.
Galaxy S9+ OneUI 2.5 here too, and I’m in the US. So @Paul_Oliver is probably right - it seems to be a regional thing.
