Ok, I am going to make this really easy for everybody. 1st use the below code and go into the IDE and create the DTH. Next take hue motion out of the box. Pull the plastic tab from the back, go to ST mobile app, click on add a thing. And that is it. Only thing you will need to do is set the LUX off set in the mobile app once installed.
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Hue Motion Sensor", namespace: "digitalgecko", author: "digitalgecko") {
capability "Motion Sensor"
capability "Configuration"
capability "Battery"
capability "Refresh"
capability "Temperature Measurement"
capability "Sensor"
capability "Illuminance Measurement" //0x0400
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0406,0400,0402", outClusters: "0019", manufacturer: "Philips", model: "SML001", deviceJoinName: "Hue Motion Sensor"
preferences {
section {
input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter '-5'. If 3 degrees too cold, enter '+3'.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input "tempOffset", "number", title: "Degrees", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
section {
input title: "Luminance Offset", description: "This feature allows you to correct the luminance reading by selecting an offset. Enter a value such as 20 or -20 to adjust the luminance reading.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input "luxOffset", "number", title: "Lux", description: "Adjust luminance by this amount", range: "*..*", displayDuringSetup: false
tiles(scale: 2) {
multiAttributeTile(name:"motion", type: "generic", width: 6, height: 4){
tileAttribute ("device.motion", key: "PRIMARY_CONTROL") {
attributeState "active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0"
attributeState "inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff"
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
state "battery", label:'${currentValue}% battery', unit:""
valueTile("illuminance", "device.illuminance", width: 2, height: 2) {
state("illuminance", label:'${currentValue}', unit:"lux",
backgroundColors:[
[value: 9, color: "#767676"],
[value: 315, color: "#ffa81e"],
[value: 1000, color: "#fbd41b"]
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"configure", action:"configure"
main "motion"
details(["motion","temperature","battery", "refresh","illuminance",'configure'])
// Parse incoming device messages to generate events
def msg = zigbee.parse(description)
//log.warn "--"
//log.trace description
//log.debug msg
//def x = zigbee.parseDescriptionAsMap( description )
//log.error x
Map map = [:]
if (description?.startsWith('catchall:')) {
map = parseCatchAllMessage(description)
else if (description?.startsWith('temperature: ')) {
map = parseCustomMessage(description)
else if (description?.startsWith('illuminance: ')) {
// else if (description?.startsWith('zone status')) {
// //map = parseIasMessage(description)
// log.trace "zone status"
def result = map ? createEvent(map) : null
if (description?.startsWith('enroll request')) {
List cmds = enrollResponse()
result = cmds?.collect { new physicalgraph.device.HubAction(it) }
else if (description?.startsWith('read attr -')) {
result = parseReportAttributeMessage(description).each { createEvent(it) }
return result
Refresh Function
def refresh() {
log.debug "Refreshing Values"
def refreshCmds = []
refreshCmds +=zigbee.readAttribute(0x0001, 0x0020) // Read battery?
refreshCmds += zigbee.readAttribute(0x0402, 0x0000) // Read temp?
refreshCmds += zigbee.readAttribute(0x0400, 0x0000) // Read luminance?
refreshCmds += zigbee.readAttribute(0x0406, 0x0000) // Read motion?
return refreshCmds + enrollResponse()
Configure Function
def configure() {
// TODO : device watch?
String zigbeeId = swapEndianHex(device.hub.zigbeeId)
log.debug "Confuguring Reporting and Bindings."
def configCmds = []
configCmds += zigbee.batteryConfig()
configCmds += zigbee.temperatureConfig(60, 600) // Set temp reporting times // Confirmed
configCmds += zigbee.configureReporting(0x406,0x0000, 0x18, 10, 600, null) // motion // confirmed
// Data type is not 0x20 = 0x8D invalid data type Unsigned 8-bit integer
configCmds += zigbee.configureReporting(0x400,0x0000, 0x21, 30, 600, 0x20) // Set luminance reporting times?? maybe
return refresh() + configCmds
getMotionResult
private Map getMotionResult(value) {
//log.trace "Motion : " + value
def descriptionText = value == "01" ? '{{ device.displayName }} detected motion':
'{{ device.displayName }} stopped detecting motion'
return [
value: value == "01" ? "active" : "inactive",
descriptionText: descriptionText,
translatable: true,
getTemperatureResult
private Map getTemperatureResult(value) {
//log.trace "Temperature : " + value
if (tempOffset) {
def offset = tempOffset as int
def v = value as int
value = v + offset
def descriptionText = temperatureScale == 'C' ? '{{ device.displayName }} was {{ value }}°C':
'{{ device.displayName }} was {{ value }}°F'
return [
value: value,
translatable: true,
unit: temperatureScale
def getTemperature(value) {
def celsius = Integer.parseInt(value, 16).shortValue() / 100
if(getTemperatureScale() == "C"){
return Math.round(celsius)
} else {
return Math.round(celsiusToFahrenheit(celsius))
private Map getLuminanceResult(rawValue) {
log.debug "Luminance rawValue = ${rawValue}"
if (luxOffset) {
def offset = luxOffset as int
def v = rawValue as int
rawValue = v + offset
def result = [
value: '--',
translatable: true,
unit: 'lux'
result.value = rawValue as Integer
return result
getBatteryResult
//TODO: needs calibration
private Map getBatteryResult(rawValue) {
//log.debug "Battery rawValue = ${rawValue}"
def result = [
value: '--',
translatable: true
def volts = rawValue / 10
if (rawValue == 0 || rawValue == 255) {}
else {
if (volts > 3.5) {
result.descriptionText = "{{ device.displayName }} battery has too much power: (> 3.5) volts."
else {
if (device.getDataValue("manufacturer") == "SmartThings") {
volts = rawValue // For the batteryMap to work the key needs to be an int
def batteryMap = [28:100, 27:100, 26:100, 25:90, 24:90, 23:70,
22:70, 21:50, 20:50, 19:30, 18:30, 17:15, 16:1, 15:0]
def minVolts = 15
def maxVolts = 28
if (volts < minVolts)
volts = minVolts
else if (volts > maxVolts)
volts = maxVolts
def pct = batteryMap[volts]
if (pct != null) {
result.value = pct
result.descriptionText = "{{ device.displayName }} battery was {{ value }}%"
else {
def minVolts = 2.1
def maxVolts = 3.0
def pct = (volts - minVolts) / (maxVolts - minVolts)
def roundedPct = Math.round(pct * 100)
if (roundedPct <= 0)
roundedPct = 1
result.value = Math.min(100, roundedPct)
return result
parseCustomMessage
private Map parseCustomMessage(String description) {
Map resultMap = [:]
def value = zigbee.parseHATemperatureValue(description, "temperature: ", getTemperatureScale())
resultMap = getTemperatureResult(value)
log.warn "value: " + description.split(": ")[1]
log.warn "proc: " + value
def value = zigbee.lux( description.split(": ")[1] as Integer ) //zigbee.parseHAIlluminanceValue(description, "illuminance: ", getTemperatureScale())
resultMap = getLuminanceResult(value)
return resultMap
private List parseReportAttributeMessage(String description) {
Map descMap = (description - "read attr - ").split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
List result = []
// Temperature
if (descMap.cluster == "0402" && descMap.attrId == "0000") {
def value = getTemperature(descMap.value)
result << getTemperatureResult(value)
// Motion
else if (descMap.cluster == "0406" && descMap.attrId == "0000") {
result << getMotionResult(descMap.value)
// Battery
else if (descMap.cluster == "0001" && descMap.attrId == "0020") {
result << getBatteryResult(Integer.parseInt(descMap.value, 16))
// Luminance
else if (descMap.cluster == "0402" ) { //&& descMap.attrId == "0020") {
log.error "Luminance Response " + description
//result << getBatteryResult(Integer.parseInt(descMap.value, 16))
return result
private Map parseCatchAllMessage(String description) {
Map resultMap = [:]
def cluster = zigbee.parse(description)
// log.debug cluster
if (shouldProcessMessage(cluster)) {
switch(cluster.clusterId) {
case 0x0001:
// 0x07 - configure reporting
if (cluster.command != 0x07) {
resultMap = getBatteryResult(cluster.data.last())
break
case 0x0400:
if (cluster.command == 0x07) { // Ignore Configure Reporting Response
if(cluster.data[0] == 0x00) {
log.trace "Luminance Reporting Configured"
sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
else {
log.warn "Luminance REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
else {
log.debug "catchall : luminance" + cluster
resultMap = getLuminanceResult(cluster.data.last());
break
case 0x0402:
log.trace "Temperature Reporting Configured"
else {
log.warn "TEMP REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
else {
// temp is last 2 data values. reverse to swap endian
String temp = cluster.data[-2..-1].reverse().collect { cluster.hex1(it) }.join()
def value = getTemperature(temp)
break
return resultMap
private boolean shouldProcessMessage(cluster) {
// 0x0B is default response indicating message got through
boolean ignoredMessage = cluster.profileId != 0x0104 ||
cluster.command == 0x0B ||
(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
return !ignoredMessage
// This seems to be IAS Specific and not needed we are not really a motion sensor
def enrollResponse() {
// log.debug "Sending enroll response"
// String zigbeeEui = swapEndianHex(device.hub.zigbeeEui)
// //Resending the CIE in case the enroll request is sent before CIE is written
// "zcl global write 0x500 0x10 0xf0 {${zigbeeEui}}", "delay 200",
// "send 0x${device.deviceNetworkId} 1 ${endpointId}", "delay 500",
// //Enroll Response
// "raw 0x500 {01 23 00 00 00}", "delay 200",
// "send 0x${device.deviceNetworkId} 1 1", "delay 200"
def configureHealthCheck() {
Integer hcIntervalMinutes = 12
refresh()
sendEvent(name: "checkInterval", value: hcIntervalMinutes * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
def updated() {
log.debug "in updated()"
def ping() {
return zigbee.onOffRefresh()
private getEndpointId() {
new BigInteger(device.endpointId, 16).toString()
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
