[~~~~Duplicate thread~~~~]
Hi team,
Has anyone get experience with this motion sensor being directly connected to a ST hub? I’ve been using the Samsung Smartthings motion sensor outside for about a year to turn on/off some outside lights but it has finally succumbed to the elements so need to replace it and found the Philips as a proper outdoor alternative.
I’ll want to connect it into ST and my V3 hub and then use the motion sensing to active a set of outdoor lights … just wanted to check it can work as a drop-in replacement for the Samsung ST Motion sensor i’ve killed…don’t want to buy separate hubs etc just for this device.
Thanks in advance.
This was one of the first devices that I added to my V3 hub over the summer. I recommend the custom DTH in the post linked below (link goes directly to the recommended changes to the DTH, so you don’t miss them).
Thanks, got the sensor today and this worked a treat.
