Is there a way to add PANIC button to my SMARTTHINGS mobile app? Basically a way to trigger the siren only?
A virtual switch, and a single rule in Simple Rule Builder that activates the alarm when the virtual switch is on.
What kind of mobile device do you have? (Eg. Android or iOS)
Thank you for responding. I will give this a try.
Thank you for responding. I use Android devices.
You could use an app I developed called SharpTools to create a widget to directly make your siren trigger.
SharpTools lets you easily create widgets that interact with SmartThings (and has a set of plugins for Tasker).
